[GRASS-dev] import/export projection error
Hello,
I just encountered a very peculiar error.
import of latlong/WGS84 geotif
import of latlong/WGS84 shp
border fits well
export of latlong/WGS84 asc/img etc. via r.out.gdal
load GRASS export asc into QGIS plus shp layer:
upper left: border fits good
middle left: border is shifted slightly
lower right: border does not fit at all
load original geotif into QGIS, overlay with shp layer: border fits
it is a continental raster/shp - perhaps only this extent makes the problem
visible.
I attached the original raster + shp and the GRASS exported raster + shp in
QGIS
if somebody wants to have the original files for testing, please feel free to
contact me.
cheers, Martin
Martin Wegmann
DLR - German Aerospace Center
German Remote Sensing Data Center
Dept.of Geography
Remote Sensing and Biodiversity Unit
Dept. of Animal Ecology and Tropical Biology
University of Wuerzburg
Am Hubland
97074 Würzburg
phone: +49-(0)931 - 888 4797
mobile: +49-(0)175 2091725
fax: +49-(0)931 - 888 4961
http://www.biota-africa.org
http://www.biogis.de
(attachments)
the shift only happens for r.out.gdal export of AAIGrid not for geotiff or
hfa.
So far it seems that the 3 ( and upward) decimal place of the pixel size
(AAIGrid exports only) differs from the original (and GRASS imported) file
what causes the error on a very large scale.
regards, Martin
On Friday 05 May 2006 18:43, Martin Wegmann wrote:
Hello,
border fits well
visible.
QGIS
to contact me.
cheers, Martin
Martin Wegmann
Dept.of Geography
Am Hubland
97074 Würzburg
well, as far as I understand AAIGrid now, it stores one value for raster file
resolution only. If the values (nsres/ewres) differs slightly the single
resolution value in the AAIGrid export file holds a wrong resolution for ns
or ew which is only visible if number of columns/rows is high (e.g. high
resolution imagery or continental scale raster file).
It can be solved by setting g.region to the same nsres/ewsres and resample the
respective raster files before exporting the raster.
If my error detection result is correct then I would suggest that r.out.gdal
prompts a warning for AAIgrid if g.region nsres/ewres resolution differs.
Martin
hfa.
regards, Martin
> Hello,
> border fits well
> problem visible.
> in QGIS
> free to contact me.
> cheers, Martin
Martin Wegmann
Dept.of Geography
Am Hubland
97074 Würzburg
