I am trying to import a vector layer from a PostGIS database in GRASS
GIS (7.8.3dev, GDAL 3.0.2, Ubuntu 18.04) , but a large number of the
polygons are skipped with the following warnings:
WARNING: Skipping unsupported geometry type 'CURVEPOLYGON'
I though, but am not sure, that these polygons were imported without
problems before I last updated grass and gdal (running grass gis
7.8.0, gdal 2.4).
Is there any way I can import those problematic curvepolygons in grass gis?
WARNING: Skipping unsupported geometry type ‘CURVEPOLYGON’
7.8.0, gdal 2.4).
These CURVEPOLYGON polygons should be imported without problems in GRASS GIS 7.6+ compiled with GDAL 2+. Can you provide an extract created with ogr2ogr in GeoPackage format that contains such polygons for testing? That would help reproduce the problem.
Markus M
On Sat, Dec 28, 2019 at 10:45 PM Markus Metz
<markus.metz.giswork@gmail.com> wrote:
On Fri, Dec 27, 2019 at 4:49 PM Paulo van Breugel <p.vanbreugel@gmail.com> wrote:
> Hi devs,
> 7.8.0, gdal 2.4).
Indeed, last time I worked with this data was before I upgraded to
gdal 3.02 (using the ppa https://qgis.org/ubuntugis/) and grass
7.8.3dev.
See attached a small sample (the original data is the BGT postgis dump
from https://nlextract.nl/downloads/), as well as a screenshot of the
data opened in QGIS and the same data imported in grass with v.in.ogr.
Markus M
> Mvg.
> Paulo
> grass-dev mailing list
> grass-dev@lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/grass-dev
7.8.0, gdal 2.4).
7.8.3dev.
Thanks for the test data, I could reproduce the problem, fixed in master 264f753 and relbr78 7da40bf
Markus M
Markus M
On Sun, Dec 29, 2019 at 12:37 PM Markus Metz
On Sat, Dec 28, 2019 at 11:46 PM Paulo van Breugel <p.vanbreugel@gmail.com> wrote:
> > > Hi devs,
> > > 7.8.0, gdal 2.4).
> 7.8.3dev.
Great, I can confirm it correctly imports the test data. Thanks!
Markus M
> > Markus M
> > > Mvg.
> > > Paulo
> > > _______________________________________________
