[GRASS-dev] Importing/Exporting Vis5D standar files
Dear GRASS devs,
Thanks so much for all your help in the user's forums in the topic "Reprojection from LLC to UTM (various zones)", so many time ago, also for sending location examples created with r3.out.v5d/r3.in.v5d.
It led me to discover the problem and I knew Nviz's issues ... I was focused in the wrong place. The problem is in the way that r3.in.v5d reads the data stored in the vis5D file, in a standar form, that is to say, now I can import, for example, a vis5d example file distributed with the program, like hole.v5d.
I correct the function and also I've been working on making directly the correct region settings from the v5d file, depending about the projection used on the file.
If this is interesting for you (I know Vis5D is dead software really), I'm very glad to help the comunnity in the way I can do it.
Greetings,
Miriam
<> Miriam España Acebal
<> Ingeniera en Informatica / Computer Science Engineer
<> Departamento de Lenguajes y Sistemas Informaticos / Software Engineering Department
<> G. I. Informatica Grafica / Computer Graphics Research Group
<> Universidad de Granada / University of Granada
<> España / Spain
<> mespana at ugr.es
<> Tel./ Ph.: +34 958 24 05 80
