I cant import very large data in GRASS7 && G6. it reads the features but hangs with 98% Breaking Boundaries when building topology
I am using latest grass from svn maybe 3 days old
If somebody needs to test for this problem you can get data here[1]
[1] http://www.gadm.org/data2/gadm_v2_shp.zip
Rashad
On Mon, Feb 11, 2013 at 9:55 AM, Rashad M <mohammedrashadkm@gmail.com> wrote:
This is indeed a very large dataset. You can try to import only the
part overlapping with your area of interest: first set the region
accordingly, then use v.in.ogr -r
Markus M
But I need the whole data and to do some geo processing over it.
On Mon, Feb 11, 2013 at 3:18 PM, Markus Metz <markus.metz.giswork@gmail.com> wrote:
Markus M
Rashad
On Mon, Feb 11, 2013 at 11:30 AM, Rashad M <mohammedrashadkm@gmail.com> wrote:
OK. In contrast to GADM v1, GADM v2 contains a lot of floating point
representation errors in the coordinates, most probably created by the
software used to create GADM v2. You need to perform additional
cleaning with snapping to a very small threshold, i.e. v.in.ogr
snap=1e-7. And you should use GRASS 7 for the import of large vector
data, because the import may not work with GRASS 6.
Markus M
wrote:
> Hi,
Markus M
Rashad
On Mon, Feb 11, 2013 at 12:27 PM, Markus Metz <markus.metz.giswork@gmail.com> wrote:
FAQ added here http://grasswiki.osgeo.org/wiki/Importing_large_vector_data
ciao madi
Markus M
wrote:
Markus M
Rashad
grass-dev mailing list
grass-dev@lists.osgeo.org
Margherita DI LEO
Postdoctoral Researcher
European Commission - DG JRC
Institute for Environment and Sustainability (IES). Unit H03 – FRC
Via Fermi, 2749
I-21027 Ispra (VA) - Italy - TP 261
Tel. +39 0332 78 3600
margherita.di-leo@jrc.ec.europa.eu
Disclaimer: The views expressed are purely those of the writer and may not in any circumstance be regarded as stating an official position of the European Commission.
