I’m recently having trouble importing the dbf table of a shape file (generated by QGIS) into GRASS 7.2 to 7.5. I get the error listed below. I don’t know if it is a bug I need to report or something wrong with the table. Has anyone else run into similar issues?
SQLITE works fine on existing GRASS vectors. I just can’t import some shape files recently.
Michael
v.import -o --overwrite input=/Users/cmbarton/Dropbox (ASU)/Conferences&Meetings/2018/EAA 2018/data/SP_NV_7_GIS_DATA/SP_NV_07_column_location.shp layer=SP_NV_07_column_location
Over-riding projection check
Check if OGR layer <SP_NV_07_column_location> contains polygons…
WARNING: Vector map <SP_NV_07_column_location> already exists and will be overwritten
dyld: Library not loaded: @rpath/libncurses.6.dylib
Referenced from: /Applications/GRASS-7.2.2.app/Contents/Re
sources/lib/libsqlite3.0.dylib
Reason: image not found
dbmi: Protocol error
WARNING: Unable to start driver
WARNING: Unable open database </Users/cmbarton/Dropbox (ASU)/GRASS_dropbox/grassdata_dropbox/Global_latlon/EAA2018/sqlite/sqlite.db> by driver
WARNING: Unable to find table <SP_NV_07_column_location> linked to vector map <SP_NV_07_column_location>
ERROR: Unable to open database </Users/cmbarton/Dropbox (ASU)/GRASS_dropbox/grassdata_dropbox/Global_latlon/EAA2018/sqlite/sqlite.db> by driver
ERROR: Unable to import </Users/cmbarton/Dropbox (ASU)/Conferences&Meetings/2018/EAA 2018/data/SP_NV_7_GIS_DATA/SP_NV_07_column_location.shp>
