Hi All,
This is my report for Week 4 (June 4 - June 10):
What did you get done this week?
- I finalized the library for parsing description files for QGIS Processing plugin. [1]
- Add ‘Controversy decision’ in building the parser to wiki. [2]
What do you plan on doing next week?
- Split GRASS module parameters in Processing plugin to basic and advanced tabs - it should be required and optional tab.
- Check GRASS X QGIS parameter descriptions in order to take care of differences in terminology.
Are you blocked on anything?
- No, at the moment I’m not blocked.
[1] https://github.com/radeknovotny94/GRASS_Parse_to_QGIS_UI
[2] https://trac.osgeo.org/grass/wiki/GSoC/2018/IntegrationInQGIS3
Hi Radek,
Le Sun, 10 Jun 2018 23:26:10 +0200,
Radek Novotný <radeknovotny94@gmail.com> a écrit :
Hi All,
*What did you get done this week?*
Nice !
I just tested it here, and noticed that the desc and xml file
description texts are in the locale defined language. Is this a desired
effect or should these texts be in English ?
- Add 'Controversy decision' in building the parser to wiki. [2]
I don't know how this was discussed with your mentors, but maybe some
of these decisions should be discussed on the mailing list ?
Moritz
Hi Nyall,
Looks great again, making very nice progress!
I'm wondering, have you tried yet to generate a diff of the output of
your tool vs the current processing txt descriptions? I'd be keen to
see the results of this as soon as it can be done, because I suspect
this diff will reveal some issues in the current description files
which would be good to fix before 3.2 final release.
That is good idea, I want to do it this week.
Radek
