Markus Neteler wrote:
GRASS 7.1.svn (nc_spm_08_grass7):~ > v.to.rast roadsmajor out=test
use=attr attrcol=PROPYEAR memory=3000000 --o
WARNING: No areas selected from vector map <roadsmajor>
Current region rows: 135000, cols: 150000
ERROR: G_calloc: unable to allocate 18446744072484715136 * 4 bytes of
memory at vector/v.to.rast/raster.c:84
$ printf '%x' 18446744072484715136
ffffffffb6fe7a80
Those leading "f"s are a giveway. It's almost certain that a
calculation was done with 32-bit arithmetic, which overflowed to
produce a negative result (0xb6fe7a80 = -1224836480), which was then
converted to 64 bits with sign extension, then cast to unsigned.
... only, it does not return to command line (have to use CTRL-C).
It's possible that memory corruption has already occurred, resulting
in e.g. an infinite loop.
A great deal of GRASS code still uses "int" where it should be using
"long", "long long", "size_t" or "ssize_t". Fixing this is far from
straightforward as:
1. It's likely to be a lot of work.
2. I don't know of any easy way to detect such cases.
3. We still haven't decided upon the appropriate type. All of the
options have drawbacks; to recap:
long - only 32 bits on 64-bit versions of Windows
long long - not specified by C89
size_t - unsigned
ssize_t - POSIX; not specified by any version of ISO C
Also: Windows' write() function uses "int" for the count argument and
the return value, so it can't handle more than 2 GiB at a time.
Likewise for read().
>> Yet a bit unhelpful It comes from lib/segment/format.c but I
>> didn't manage to improve that.
> Specifically:
> if (write(fd, buf, n) != n) {
> G_warning("segment zero_fill(): Unable to write (%s)", strerror(errno));
> ENOENT ("No such file or directory") isn't a valid error code for
> write(). But errno is only set if write() returns -1, so it's likely
> that write() returned a short count rather than failing and the errno
> value is left over from a previous system call (sucessful calls don't
> reset errno to zero). In all probability, the next call to write()
> would have failed due to ENOSPC, EDQUOT, or EFBIG (or raised SIGXFSZ
> if RLIMIT_FSIZE is being exceeded).
I see and now darkly remember something about discussion in this list
about clearing the previous error state.
The main issue here is that errno is being examined when write() has
reported a short count (a non-negative return value less than the
value of the third argument) rather than an error (returning -1).
The code should either distinguish these cases, or use something like:
ssize_t writen(int fd, const void *buf, size_t count)
size_t left = count;
const char *ptr = buf;
while (left > 0) {
ssize_t n = write(fd, ptr, left);
if (n <= 0)
return -1;
ptr += n;
left -= n;
return count;
This never returns a short count; it either writes (and returns) the
exact number of bytes requested or returns -1 (errno won't be changed
if write() returns 0, but that should only occur when the third
argument is 0; if write() can't write *anything*, that's an error
condition).
