[GRASS-dev] in trunk png/cairo d.vect overwrites previous images?
Hello,
I ask here first before because this seems a bit weird that nobody else
reported it, but maybe I missed a bug report or something changed in grass
7?
When doing more than one d.vect after a d.mon start=png (or cairo) the
last one overwrite completly the previous one. With wx0 or 6.4 the
vector was on top but did not remove the previous vector.
Should I report that or is it known?
Pat
On 31/01/12 00:20, Patrice Dumas wrote:
Hello,
7?
This behaviour is controlled by the GRASS_PNG_READ environment variable. If you set it to TRUE, then GRASS will lay the new d.vect on top of the already drawn vectors, otherwise it overwrites with the new. See http://grass.osgeo.org/grass70/manuals/html70_user/cairodriver.html.
Moritz
Thanks. I was pretty sure I missed something although I did read the
Fine Manual before asking... Maybe the GRASS_PNG_READ description
could be enhanced by adding
  Otherwise the GRASS_PNGFILE file content is overwritten each time
  a new display command is used.
Also I think that the Example should also set
  export GRASS_PNG_READ=TRUE
otherwise it doesn't really make sense as the elevation raster will not
appear on map.png.
Pat
Will do, thanks for the suggestion.
appear on map.png.
Here's what I see as example on the page:
export GRASS_RENDER_IMMEDIATE=cairo
export GRASS_WIDTH=800
export GRASS_HEIGHT=800
g.region rast=elevation
d.rast map=elevation
d.vect map=streams width=1 color=blue fcolor=aqua type=area,line
d.vect map=roadsmajor width=2
i.e. GRASS_PNG_READ is set... :slight_smile:
Moritz
>appear on map.png.
Ah, ok, I was looking at
http://grass.osgeo.org/grass70/manuals/html70_user/pngdriver.html
There it is not set.
Pat
