[GRASS-dev] Incomplete raster history in r.mapcalc
hi,
by chance I observed a detail:
GRASS 6.4.2svn (utm49n):~ > r.mapcalc "L5120060_06020060925_ndwi = 1.0
* (L5120060_06020060925_toar.4 - L5120060_06020060925_toar.5) /
(L5120060_06020060925_toar.4 + L5120060_06020060925_toar.5)"
100%
-> 1.0
GRASS 6.4.2svn (utm49n):~ > r.info -h L5120060_06020060925_ndwi
Data Source:
Data Description:
   generated by r.mapcalc
Comments:
   1 * (L5120060_06020060925_toar.4 - L5120060_06020060925_toar.5) /
-> 1
? I wonder where this get's eaten...
100%
-> 1.0
Data Source:
Data Description:
Comments:
-> 1
  static char *format_constant(const expression * e)
      char buff[64];
      if (e->res_type == CELL_TYPE)
    sprintf(buff, "%d", e->data.con.ival);
      else
    sprintf(buff, "%.8g", e->data.con.fval);
      return strdup(buff);
"%g" omits trailing zeros, and omits the decimal point if nothing
follows it. Using "%#.8g" would retain the decimal point and the
trailing zeros (G_trim_decimal() could be used to remove those).
