for a calculation I need to loop over all vector features in a map in
order to perform individually a computation. For that I cannot use the
category information since it may be used as 1:n link.
I wonder if a new v.clump command would make sense or the addition of
a new method in v.category to simplify this task?
Eventually I would implement the processing loop as a Python script.
On Wed, Dec 3, 2014 at 5:51 PM, Markus Neteler <neteler@osgeo.org> wrote:
Adding unique categories to a new layer for the features in question
with v.category (take care of the type option) does not work in this
case?
Markus M
grass-dev mailing list
grass-dev@lists.osgeo.org
On Wed, Dec 3, 2014 at 9:47 PM, Markus Metz
case?
Likely it does (I am asking on behalf on another person not subscribed here).
I wonder how to make it more obvious. And, if there is a best
practice example written in Python/PyGRASS?
case?
For Python, you can have a look at g.gui.rlisetup for an example about
how to cycle through all vector features of a given type.
Markus M
Hi Markus,
case?
with pygrass at the moment the pseudo code is something like:
with VectorTopo('yourvectormap', mode='r') as vect:
for line in vect.viter('lines'):
# do something with line
pass
for area in vect.viter('areas'):
# do something with area
pass
but I'm thinking to change how to iter between vector features to make
the distinction between topological and not topological features
clearer, something like:
for line in vect.features.lines:
pass
for area in vect.topo.areas: # nodes, centroid, etc.
pass
But I'm still thinking on it...
Best regards
Pietro
