Checking package.log, it seems that the error stems from the absence of a Platform.make file. Does anyone know a fix to this?
include/Make/Vars.make:1: include/Make/Platform.make: No such file or directory
make: *** No rule to make target ‘include/Make/Platform.make’.
make: Failed to remake makefile ‘include/Make/Platform.make’.
/dist.
make: /dist.: Command not found
make: *** [include/Make/Rules.make:16: /dist.] Error 127
directory
make: *** No rule to make target 'include/Make/Platform.make'.
make: Failed to remake makefile 'include/Make/Platform.make'.
/dist.
Jerry
grass-dev mailing list
Maybe change the subject of your mail to 'compiling on Windows'.
a package.log should have been created.
could you post here the relevant part of configure in package.log?
It should look similar to
"Sat Dec 2 00:20:39 2017: STARTING configure
checking host system type... x86_64-w64-mingw32
checking for gcc... gcc
checking whether the C compiler (gcc
-L/c/msys64/usr/src/grass_trunk/mswindows/osgeo4w/lib -lz) works... yes
-L/c/msys64/usr/src/grass_trunk/mswindows/osgeo4w/lib -lz) is a
cross-compiler... no
checking whether we are using GNU C... yes
checking whether gcc accepts -g... yes
checking for Cygwin environment... no
checking for mingw32 environment... yes
checking for executable suffix... .exe
checking for full floating-point support... yes
checking for pwd... /usr/bin/pwd
checking for source directory... /c/msys64/usr/src/grass_trunk
checking for build directory... /c/msys64/usr/src/grass_trunk
checking for svnversion... /usr/bin/svnversion
checking for MacOSX App... no
checking for MacOSX architectures... no
checking for MacOSX SDK... no
checking how to build libraries... shared
checking for additional include dirs... /c/OSGeo4W64/include
checking for additional library dirs...
to be precise you are not installing GRASS but creating binary
packages which you or someone else can install. BTW, those binary
packages are available on daily basis at [1] (daily builds for
grass72_release are not provided since 26/11, so I put link to
grass74_release). Why can't you use precompiled binaries from [1]?
Jerry is a GCI student who tries to complete some of the GRASS tasks.
Okay I switched to a terminal with gcc and ran ./configure again. This time I get the following error:
loading site script /mingw64/etc/config.site
/mingw64/etc/config.site: line 13: config.site:13: default build_alias set to x86_64-w64-mingw32: command not found
/mingw64/etc/config.site: line 20: config.site:20: default prefix set to /mingw64: No such file or directory
checking host system type… x86_64-pc-mingw64
checking for gcc… gcc
checking whether the C compiler (gcc ) works… yes
checking whether the C compiler (gcc ) is a cross-compiler… no
checking whether we are using GNU C… yes
checking whether gcc accepts -g… yes
checking for Cygwin environment… no
checking for mingw32 environment… yes
checking for executable suffix… .exe
checking for full floating-point support… yes
checking for pwd… /usr/bin/pwd
checking for source directory… /usr/src/grass72_release
checking for build directory… /usr/src/grass72_release
checking for svnversion… /usr/bin/svnversion
checking for MacOSX App… no
checking for MacOSX architectures… no
checking for MacOSX SDK… no
checking how to build libraries… shared
configure: error: Unknown platform: x86_64-pc-mingw64
My package.log is linked below. Running configure by itself gives:
loading site script /etc/config.site
/etc/config.site: line 23: config.site:23: default build_alias set to x86_64-pc-msys: command not found
/etc/config.site: line 30: config.site:30: default prefix set to /usr: No such file or directory
checking host system type… x86_64-pc-msys
checking for gcc… no
checking for cc… no
configure: error: no acceptable cc found in $PATH
Ok I made some progress in compiling the code. I first switched to 32 bit msys because ./configure couldn’t detect the 64 bit version. I also switched to compiling grass_trunk as I suspected something was wrong with my grass72_release (my Platform.make file was missing). However, I ran into different errors this time.
Below is my error.log:
/usr/src/grass_trunk/lib/python/ctypes
/usr/src/grass_trunk/raster/r.cost
/usr/src/grass_trunk/raster/r.flow
/usr/src/grass_trunk/raster/r.resamp.bspline
/usr/src/grass_trunk/raster/r.spreadpath
/usr/src/grass_trunk/raster/r.stream.extract
/usr/src/grass_trunk/raster/r.terraflow
/usr/src/grass_trunk/raster/r.viewshed
/usr/src/grass_trunk/raster/r.walk
/usr/src/grass_trunk/vector/v.lidar.correction
/usr/src/grass_trunk/vector/v.lidar.edgedetection
/usr/src/grass_trunk/vector/v.outlier
/usr/src/grass_trunk/vector/v.surf.bspline
/usr/src/grass_trunk/imagery/i.segment
/usr/src/grass_trunk/locale
Running make in ctypes gives:
File “./ctypesgen.py”, line 142, in
ctypesgencore.processor.process(descriptions, options)
File “./ctypesgencore/processor/pipeline.py”, line 58, in process
find_source_libraries(data, options)
File “./ctypesgencore/processor/operations.py”, line 206, in find_source_libraries
library = ctypesgencore.libraryloader.load_library(library_name)
File “./ctypesgencore/libraryloader.py”, line 62, in load_library
return self.load(path)
File “./ctypesgencore/libraryloader.py”, line 240, in load
return _WindowsLibrary(path)
File “./ctypesgencore/libraryloader.py”, line 223, in init
self.cdll = ctypes.cdll.LoadLibrary(path)
File “C:/msys64/mingw32/lib/python2.7/ctypes/init.py”, line 444, in LoadLibrary
return self._dlltype(name)
File “C:/msys64/mingw32/lib/python2.7/ctypes/init.py”, line 366, in init
self._handle = _dlopen(self._name, mode)
WindowsError: [Error 127] The specified procedure could not be found
make[1]: *** [Makefile:102: OBJ.i386-w64-mingw32/segment.py] Error 1
make[1]: Leaving directory ‘/usr/src/grass_trunk/lib/python/ctypes’
make: *** [Makefile:81: default] Error 2
