A computer science student of our university will probably start working on an active learning framework for image classification in GRASS. This means (in brief) selecting some pixels/objects and assigning them to a class, using them to train a machine learning classifier and then identifying those unclassified pixels/objects that would best improve the classification if the user assigned them a class.
There will, therefore, be some interaction between the user and the GUI and I was wondering if there is some howto explaining how to approach the coding of a g.gui.* module. I know there is the GUI part of the programmers manual [1], but this is "just" a list of functions and classes, but no introduction.
Any pointers ?
Thanks !
Moritz
[1] https://grass.osgeo.org/programming6/wxpythonlib.html
On Mon, Oct 17, 2016 at 11:59 AM, Moritz Lennert
<mlennert@club.worldonline.be> wrote:
introduction.
Any pointers ?
I believe the only thing there is is this example of GUI application:
https://trac.osgeo.org/grass/browser/grass/trunk/doc/gui/wxpython/example
but I am pretty sure it needs to be updated, because it's couple years old.
Anna
Thanks !
Moritz
grass-dev mailing list
grass-dev@lists.osgeo.org
Le 17 octobre 2016 18:10:59 GMT+02:00, "Anna Petrášová" <kratochanna@gmail.com> a écrit :
working on
means
class,
identifying those
classification if
GUI and
coding
manual
introduction.
Any pointers ?
old.
Thanks, Anna !
Moritz
Anna
Thanks !
Moritz
introduction.
Any pointers ?
Well, for starters,
make MODULE_TOPDIR=../../../../dist.x86_64-pc-linux-gnu/
gives me:
File "/home/mlennert/SRC/GRASS/grass_trunk/dist.x86_64-pc-linux-gnu/scripts/g.gui.example", line 45, in <module>
from core.utils import _, GuiModuleMain
ImportError: cannot import name GuiModuleMain
I'll look at this more in detail when I have the time...
Moritz
On Mon, Oct 17, 2016 at 3:16 PM, Moritz Lennert
on
means
those
and
coding
manual
introduction.
Any pointers ?
old.
Well, for starters,
gives me:
File
I think I removed GuiModuleMain, which tried to fork the process
because it didn't work on other platforms than linux
Moritz
