Hi devs
Following instructions here: https://trac.osgeo.org/grass/wiki/HowToGit#Keepyourlocalsourcecodeuptodate, I get:
[veroandreo@localhost grass7_trunk]$ git remote -v
origin git@github.com:veroandreo/grass.git (fetch)
origin git@github.com:veroandreo/grass.git (push)
upstream git@github.com:OSGeo/grass.git (fetch)
upstream git@github.com:OSGeo/grass.git (push)
[veroandreo@localhost grass7_trunk]$ git fetch upstream
remote: Enumerating objects: 242, done.
remote: Counting objects: 100% (242/242), done.
remote: Compressing objects: 100% (25/25), done.
remote: Total 296 (delta 223), reused 233 (delta 217), pack-reused 54
Receiving objects: 100% (296/296), 56.83 KiB | 1.18 MiB/s, done.
Resolving deltas: 100% (226/226), completed with 105 local objects.
From github.com:OSGeo/grass
- [new branch] changelog_fix_msg → upstream/changelog_fix_msg
3797ccaaf…b300e66fc master → upstream/master
1ca5e4e34…e1e13d782 releasebranch_7_4 → upstream/releasebranch_7_4
15f53e803…dcfce280b releasebranch_7_6 → upstream/releasebranch_7_6
[veroandreo@localhost grass7_trunk]$ git branch -a
- master
remotes/origin/master
remotes/origin/releasebranch_7_0
remotes/origin/releasebranch_7_2
remotes/origin/releasebranch_7_4
remotes/origin/releasebranch_7_6
remotes/upstream/changelog_fix_msg
remotes/upstream/master
remotes/upstream/releasebranch_7_0
remotes/upstream/releasebranch_7_2
remotes/upstream/releasebranch_7_4
remotes/upstream/releasebranch_7_6
[veroandreo@localhost grass7_trunk]$ git rebase upstream/master
First, rewinding head to replay your work on top of it…
Fast-forwarded master to upstream/master.
[veroandreo@localhost grass7_trunk]$ git status
On branch master
Your branch is ahead of ‘origin/master’ by 51 commits.
(use “git push” to publish your local commits)
Why does my origin/master is now ahead by 51 commits, if I have not a single local change? I just want to get the new stuff from upstream and update my fork and local copy of the source code (what I used to do with svn update
Can someone please provide full instructions [ideally in https://trac.osgeo.org/grass/wiki/HowToGit#Keepyourlocalsourcecodeuptodate]?
Thanks much in advance
Vero
On Sun, Jun 2, 2019 at 8:59 PM Veronica Andreo <veroandreo@gmail.com> wrote:
Hi devs
On branch master
Your branch is ahead of 'origin/master' by 51 commits.
(use "git push" to publish your local commits)
Why does my origin/master is now ahead by 51 commits, if I have not a single local change? I just want to get the new stuff from upstream and update my fork and local copy of the source code (what I used to do with `svn update`).
I have pretty much the same issue on the GRASS Server, trying to
update the cronjobs:
# here on relbranch76:
neteler@osgeo6:~/cronjobs$ sh cron_grass76_src_relbr76_snapshot.sh
Sun Jun 2 12:33:42 PDT 2019
Already on 'releasebranch_7_6'
Your branch is up-to-date with 'origin/releasebranch_7_6'.
git update...
From https://github.com/OSGeo/grass
* branch releasebranch_7_6 -> FETCH_HEAD
Updating 2340b9d..dcfce28
Fast-forward
README => README.md | 78
doc/howto_release.txt | 3 +--
include/Make/Docs.make | 10 +++-------
lib/python/pygrass/modules/grid/grid.py | 7 +++++++
raster/r.stream.extract/main.c | 6 +++---
tools/gitlog2changelog.py | 133
vector/v.db.connect/main.c | 24 +++++++++++++-----------
7 files changed, 208 insertions(+), 53 deletions(-)
rename README => README.md (51%)
create mode 100755 tools/gitlog2changelog.py
On branch releasebranch_7_6
Your branch is ahead of 'origin/releasebranch_7_6' by 6 commits.
nothing to commit, working directory clean
Something is clearly missing in the "HowToGit"...
Help welcome.
thanks
On Sun, Jun 2, 2019 at 3:00 PM Veronica Andreo <veroandreo@gmail.com> wrote:
Hi devs
- master
On branch master
Your branch ‘master’ is ahead of ‘origin/master’. You need to push to origin (something like git push origin
but I think little different, Git will tell you).
BTW, you can compare what you seen on GitHub with what you see locally, e.g.
git log --graph --abbrev-commit --pretty=oneline --max-count=10
Hi Vaclav,
El dom., 2 jun. 2019 a las 21:52, Vaclav Petras (<wenzeslaus@gmail.com>) escribió:
Hi devs
- master
On branch master
but I haven’t made a single change… that’s what I don’t get. How can I be ahead?
what am I supposed to see there? If I change to 50, i see:
[veroandreo@localhost grass7_trunk]$ git log --graph --abbrev-commit --pretty=oneline --max-count=50
- f01aa67cf (HEAD → master) i18N: sync from Transifex
- 9d983ac94 Py2/Py3 compat: Use “gettext.install(…, unicode=True)” in Python 2.
- 65a5a96a6 PyGRASS GridModule silently ignores when module has no output defined, see https://trac.osgeo.org/grass/ticket/3852 (#21)
- e4835d475 v.db.addtable
- 3053328ae v.db.connect
- 85f000ebf r.stream.extract
- e5cfb9488 Python2 fixes
- e3ed0b7df super Python2 valide
- 196428874 added .github/FUNDING.yml
- 74f55730a r.out.mpeg fails because the output file name is empty
- e3418cbad change attribute/method argument name
- da230fe59 fixes
- 9a968d59e Draft intro added
- 6d0b0ded2 r.in.wms: add proxy for GDAL driver
- 94754df99 libinit: shorten GRASS prompt
- de48a8d77 r.cost/r.walk: check return code
- e9070421b libproj: fix support for PROJ6
- 29297bc2e segmentlib: malloc → calloc
- efee46fc5 v.in.ogr: fix OGR extents
- 107e3a616 Travis-CI: enable ccache for faster builds
- f1d7d2394 svn2cl replaced with tools/gitlog2changelog.py
- e240b5a60 tools/gitlog2changelog.py: added
- 8036fa977 contributors.csv: email updated
- 67a759c39 translators.csv: email update (test for grass-commit ML notification)
- 99cae4154 wxGUI/digitizer: fixes for python 3 (https://trac.osgeo.org/grass/ticket/3777)
- bf06fae1d lib/init/grass.py: Stop clearing the terminal
- 34e35a977 wxGUI About System: ‘GRASS SVN revision’ changed to more generic ‘Code revision’
- 2b570a9a0 GRASS_VERSION_SVN → GRASS_VERSION_GIT + update g.version
- 97a123681 update readme section - get write access
- 80072cf87 readme: Convert to markdown and add travis badge
- ccb7b6b28 r.contour: fix broken contour lines (#3846), clean contour lines tracing back on themselves
- c757924cc pygrass.gis: Make Region importable from grass.pygrass.gis
- 7f1dd0d9f pythonlib: fix encoding
- 9d4306801 fix tests for Python 3
- 8b9512b8b (origin/master) pygrass: fixing doctests (only for Python 3)
- ebe8eb958 pygrass: fixes for Python 3
- 4f2c2421e gunittest: when printing, it should be ‘str’ in py 2 and 3
- b29dda7dd t.rast.gapfill: fix tests
- b113de305 t.rast.univar: fix tests
- ec44b8432 pygrass: decode only if stdout/stderr not empty
Note the boldface. What does it mean?
I’m completely lost…
Vero
On Sun, Jun 2, 2019 at 4:11 PM Veronica Andreo <veroandreo@gmail.com> wrote:
Hi Vaclav,
Hi devs
- master
On branch master
Your local master branch is now in sync with upstream/master, but the commits from upstream/master are not in your origin/master (which is in GitHub fork), hence your master is ahead.
If you look at your fork’s master at GitHub, these won’t be there. (Assuming I got what is going on here.)
- da230fe59 fixes
Vero
It there a way (magic flag?) to avoid this out-of-sync in the first place?
E.g., for the cronjobs I do not want to go there weekly and "git push"
stuff around.
thanks
Hi devs
- master
On branch master
Read carefully: “Your branch is ahead of ‘origin/master’ by 51 commits.”
That means your local branch master is ahead of your fork at github: “origin git@github.com:veroandreo/grass.git”
Your local branch master is based on “upstream git@github.com:OSGeo/grass.git”, i.e. the original repo.
You need to update your fork with something like
git push origin
Don’t know if that helps,
Markus M
Vero
grass-dev mailing list
grass-dev@lists.osgeo.org
https://lists.osgeo.org/mailman/listinfo/grass-dev
On Sun, Jun 2, 2019 at 10:23 PM Markus Metz
Read carefully: "Your branch is ahead of 'origin/master' by 51 commits."
That means your local branch master is ahead of your fork at github: "origin git@github.com:veroandreo/grass.git"
Your local branch master is based on "upstream git@github.com:OSGeo/grass.git", i.e. the original repo.
git push origin
OK, let's try:
[mneteler@oboe releasebranch_7_6 ]$ git status
Your branch is ahead of 'origin/releasebranch_7_6' by 7 commits.
[mneteler@oboe releasebranch_7_6 ]$ git push origin
Enumerating objects: 31, done.
Counting objects: 100% (31/31), done.
Delta compression using up to 4 threads
Compressing objects: 100% (18/18), done.
Writing objects: 100% (18/18), 1.97 KiB | 1.97 MiB/s, done.
Total 18 (delta 14), reused 0 (delta 0)
remote: error: refusing to update checked out branch:
refs/heads/releasebranch_7_6
remote: error: By default, updating the current branch in a non-bare repository
remote: is denied, because it will make the index and work tree inconsistent
remote: with what you pushed, and will require 'git reset --hard' to match
remote: the work tree to HEAD.
remote:
remote: You can set the 'receive.denyCurrentBranch' configuration variable
remote: to 'ignore' or 'warn' in the remote repository to allow pushing into
remote: its current branch; however, this is not recommended unless you
remote: arranged to update its work tree to match what you pushed in some
remote: other way.
remote:
remote: To squelch this message and still keep the default behaviour, set
remote: 'receive.denyCurrentBranch' configuration variable to 'refuse'.
To /home/mneteler/software/grass-p2/../grass-p3/master
! [remote rejected] releasebranch_7_6 -> releasebranch_7_6
(branch is currently checked out)
error: failed to push some refs to
'/home/mneteler/software/grass-p2/../grass-p3/master'
Meep... more ideas? Cannot be so difficult
thanks
markusN
Ok, got it… the git push origin
put my origin in sync with upstream. So, for the way we have set remote/origin and remote/upstream, the update goes from upstream to local and from local to origin, is that right? Is there another way? I would have imagined, dunno why, that the update would go from upstream to origin to local…
Anyway, I think we need a new section here: https://trac.osgeo.org/grass/wiki/HowToGit
Keep your fork up to date (or in sync with upstream/master)
git fetch upstream
git push origin
I also suggest then to remove the link to sync a fork under the section “Workflow for core grass repository” if that is not the recommended procedure (git fetch + git merge) because it leads to confusion in this case.
In any case to update my local copy and recompile the source code, I could ommit the git push origin for now, though I’ll need it eventually if I make local changes myself.
Thanks for the help
Vero
El dom., 2 jun. 2019 a las 22:23, Markus Metz (<markus.metz.giswork@gmail.com>) escribió:
Hi devs
- master
On branch master
git push origin
Markus M
Vero
Right.
That would have to happen on GitHub. For whatever reason GitHub does not help you to do this automatically (I guess for case when one wants to use different workflow…).
If you are creating a new branch locally, you want your local master up to date, if on GitHub, you need also your origin/master up to date.
Hi devs
- master
On branch master
git push origin
Markus M
Vero
Hi again,
El lun., 3 jun. 2019 a las 5:16, Vaclav Petras (<wenzeslaus@gmail.com>) escribió:
Right.
However, even after the git push origin
, my fork on github website says: “This branch is 34 commits ahead, 51 commits behind OSGeo:master” (See https://github.com/veroandreo/grass).
In the terminal, all looks fine though (IIUC):
On branch master
Your branch is up to date with ‘origin/master’.
- f01aa67cf (HEAD → master, origin/master) i18N: sync from Transifex
I don’t get it…
yes, but to do a PR into upstream/master is from origin/master, no? So, I also want origin/master up to date, or I cannot do the PR. Sorry for silly questions, I just don’t fully understand (yet)
Thanks much for your patience
Vero
