OK. But GRASS 6 still has the interface in wxGUI preferences for language settings, even though it doesn't work correctly. So do we remove that apparatus (which also can cause the GUI to crash under some circumstances), or fix it?
I'm copying the rest of the dev group because this turns out to be not just a simple port, as you note.
Michael
____________________
C. Michael Barton
Arizona State University
voice: 480-965-6262 (SHESC), 480-727-9746 (CSDC)
fax: 480-965-7671 (SHESC), 480-727-0709 (CSDC)
www: http://www.public.asu.edu/~cmbarton, http://csdc.asu.edu
On Aug 16, 2012, at 10:46 AM, Maris Nartiss wrote:
Hello Michael,
it wouldn't be so easy to backport to 6, as I use Python to check if
Python has full locale support or just language has to be set. GRASS 6
still is using shell script to startup and thus needs a different
approach. Part of wxgui language switching can be backported, still it
needs also startup script magic to be fully functional.Maris.
2012/8/14 Michael Barton <Michael.Barton@asu.edu>:
Maris,
Your enhancements for international language support work very well for
GRASS 7. Have you backported them to GRASS 6 yet?Michael
C. Michael Barton
Arizona State Universityvoice: 480-965-6262 (SHESC), 480-727-9746 (CSDC)
