On 31 January 2018 at 15:31, sharry gill <sharrygill5656@gmail.com> wrote:
Hello,
Hi Sharry
I have attached a simple test, I wrote for r.mode.
I run it in nc_basic_spm_grass7 [0] but it fails
GRASS 7.5.svn (nc_basic_spm_grass7):~ > python ~/testrmode.py
ERROR: Raster map <facility> not found
E
E
F
ERROR: test_1 (__main__.Testrmode)
File "/home/lucadelu/testrmode.py", line 31, in test_1
msg="facility in degrees must be between 1 and 1")
File "/home/lucadelu/compilati/grass_trunk/dist.x86_64-pc-linux-gnu/etc/python/grass/gunittest/case.py",
line 461, in assertRasterMinMax
stdout = call_module('r.info', map=map, flags='r')
File "/home/lucadelu/compilati/grass_trunk/dist.x86_64-pc-linux-gnu/etc/python/grass/gunittest/gmodules.py",
line 131, in call_module
raise CalledModuleError(returncode, module, kwargs, errors)
CalledModuleError: Module run 1 r.info ended with error
Process ended with non-zero return code {'map': 'facility', 'flags':
'r', 'stderr': -1, 'stdout': -1}. See the following errors:
ERROR: test_2 (__main__.Testrmode)
File "/home/lucadelu/testrmode.py", line 37, in test_2
msg="slope in degrees must be between 0 and 38.68939")
Process ended with non-zero return code {'map': 'slope', 'flags': 'r',
ERROR: Raster map <slope> not found
FAIL: test_3 (__main__.Testrmode)
File "/home/lucadelu/testrmode.py", line 43, in test_3
msg="geology in degrees must be between 34300 and 43600")
line 468, in assertRasterMinMax
self.fail(self._formatMessage(msg, stdmsg))
AssertionError: geology in degrees must be between 34300 and 43600
The actual minimum (217) is smaller than the reference one (34300) for
raster map geology (with maximum 948)
Ran 3 tests in 0.905s
FAILED (failures=1, errors=2)
could you please fix it?
I am new to Open Source community so I came early, so I can get to know
about OSGeo and GRASS GIS.
Thank You
Supreet
[0] https://grass.osgeo.org/sampledata/north_carolina/nc_basic_spm_grass7.tar.gz
ciao
Luca
www.lucadelu.org
