[GRASS-dev] Invalid timestamp file for raster
This
r.timestamp B1 date='13 apr 2013 10:00:09.935626' && r.timestamp B1
WARNING: Invalid timestamp file for raster map <B1@>
does not work. Why?
The following do work:
r.timestamp B1 date='13 apr 2013 10:00:19.935626' && r.timestamp B1
13 Apr 2013 10:00:19.935626
r.timestamp B1 date='13 apr 2013 10:00:29.935626' && r.timestamp B1
13 Apr 2013 10:00:29.935626
r.timestamp B1 date='13 apr 2013 10:00:39.935626' && r.timestamp B1
13 Apr 2013 10:00:39.935626
r.timestamp B1 date='13 apr 2013 10:00:49.935626' && r.timestamp B1
13 Apr 2013 10:00:49.935626
r.timestamp B1 date='13 apr 2013 10:00:59.935626' && r.timestamp B1
13 Apr 2013 10:00:59.935626
Nikos
On Mon, Oct 23, 2017 at 6:41 PM, Nikos Alexandris
<nik@nikosalexandris.net> wrote:
This
does not work. Why?
GRASS 7.2.3svn (nc_spm_08_grass7):~ > r.mapcalc "B1 = 2"
100%
GRASS 7.2.3svn (nc_spm_08_grass7):~ > r.timestamp B1 date='13 apr
The error message is in lib/gis/timestamp.c, line 301. With debug:
GRASS 7.2.3svn (nc_spm_08_grass7):~ > g.gisenv set=DEBUG=1
D1/1: G_set_program_name(): g.gisenv
D1/1: G_set_program_name(): r.timestamp
D1/1: G_find_raster(): name=B1 mapset=
D1/1: G_find_raster(): name=B1 mapset=user1
There is apparently a parsing bug in 10:00:0x <<-- 0x (while 1x etc work).
Nikos:
This
does not work. Why?
Markus N:
100%
Obviously.
Here a quick test for 0x:
function seconds { printf "%02d" $1; }
for SEC in `seq 0 1 59` ;do echo $(seconds $SEC) && r.timestamp B1 date="13 apr 2013 10:00:$(seconds $SEC).935626" && r.timestamp B1 ;done
00
01
02
03
04
05
06
07
08
09
10
13 Apr 2013 10:00:10.935626
11
13 Apr 2013 10:00:11.935626
12
13 Apr 2013 10:00:12.935626
[..rest is fine..]
Nikos
Hi Nikos,
Have you tried with t.register?
You would need to set the start_time=“2013-04-13 10:00:09.935626” plus an increment=“10 seconds”. I have not tested, but it should work.
I think it’s better than r.timestamp if you want to create time series, even though it would be great to fix the bug in r.timestamp, anyway.
Vero
El 23 oct. 2017 7:38 p.m., “Nikos Alexandris” <nik@nikosalexandris.net> escribió:
Nikos:
This
r.timestamp B1 date=‘13 apr 2013 10:00:09.935626’ && r.timestamp B1
does not work. Why?
Markus N:
GRASS 7.2.3svn (nc_spm_08_grass7):~ > r.mapcalc “B1 = 2”
100%
GRASS 7.2.3svn (nc_spm_08_grass7):~ > r.timestamp B1 date=‘13 apr
r.timestamp B1 date=‘13 apr 2013 10:00:19.935626’ && r.timestamp B1
Obviously.
function seconds { printf “%02d” $1; }
for SEC in seq 0 1 59 ;do echo $(seconds $SEC) && r.timestamp B1 date=“13 apr 2013 10:00:$(seconds $SEC).935626” && r.timestamp B1 ;done
00
01
02
03
04
05
06
07
08
09
10
11
12
[…rest is fine…]
Nikos
grass-dev mailing list
grass-dev@lists.osgeo.org
https://lists.osgeo.org/mailman/listinfo/grass-dev
JFYI:
The temporal framework (used in t.register) ignores fractions of a
second. The smallest temporal granule is a second. Hence, it doesn't
make sense to use time-stamps for maps with fractions of a second in
the temporal framework.
Best regards
Sören
2017-10-23 22:54 GMT+02:00 Veronica Andreo <veroandreo@gmail.com>:
Hi Nikos,
You would need to set the start_time="2013-04-13 10:00:09.935626" plus an
increment="10 seconds". I have not tested, but it should work.
I think it's better than r.timestamp if you want to create time series, even
Vero
El 23 oct. 2017 7:38 p.m., "Nikos Alexandris" <nik@nikosalexandris.net>
escribió:
Nikos:
This
does not work. Why?
Markus N:
100%
work).
Obviously.
00
01
02
03
04
05
06
07
08
09
10
11
12
[..rest is fine..]
Nikos
Danke Soeren, Vero
Just trying to retain the original meta, in this case for Landsat8
imagery.
Nikos
* Sören Gebbert <soerengebbert@googlemail.com> [2017-10-23 23:08:12 +0200]:
JFYI:
Best regards
Sören
* Veronica Andreo <veroandreo@gmail.com> [2017-10-23 22:54:03 +0200]:
Hi Nikos,
I am r.timestamp-ing Landsat bands while importing them via a script and
sourcing meta from MTL files. I noticed that in some cases, the time
stamping did not work.
Cheers, Nikos
Hi Nikos, thanks Sören :slight_smile:
You can also use t.register for only one map if you want (t.register maps=single_map start=“2003-04-13 10:00:09”). In that way you timestamp them as you import.
Then you create the strds (t.create) and pass the list of already timestamped maps (t.register input=your_strds maps=list_of_maps).
Vero
El 24 oct. 2017 12:59 a.m., “Nikos Alexandris” <nik@nikosalexandris.net> escribió:
Hi Nikos,
Cheers, Nikos
Hi Nikos,
the strategy that i use is to create an input file for t.register that
contains the raster names and the time stamps for registration:
map_name | start_time | end_time
In case of Landsat scenes, there are not end-time stamps. Create this
file while importing and fill it with map names and time stamps.
Use this file with t.register and register all maps in a STRDS that
have been imported. I would suggest to create a single STRDS for each
band, so you can use map algebra for computation.
Best regards
Sören
2017-10-24 0:59 GMT+02:00 Nikos Alexandris <nik@nikosalexandris.net>:
Hi Nikos,
Cheers, Nikos
Hallo Soeren,
I think I well understand the magic behind TGIS by now.
I am doing exactly as you explain: while importing Landsat imagery, the
script (of which I am not pleased as it is now, no tests yet :-/)
- gets the MTL file
  (https://github.com/NikosAlexandris/i.landsat.import/blob/master/i.landsat.import.py#L332)
- gets the timestamp
  (https://github.com/NikosAlexandris/i.landsat.import/blob/master/i.landsat.import.py#L424)
- prints it on-screen as TGIS expects
  (https://github.com/NikosAlexandris/i.landsat.import/blob/master/i.landsat.import.py#L539)
  yet, exports in a file if requested
  (https://github.com/NikosAlexandris/i.landsat.import/blob/master/i.landsat.import.py#L542
  and
  https://github.com/NikosAlexandris/i.landsat.import/blob/master/i.landsat.import.py#L782)
I am doing my job for the moment. Yet the timestamping part needs a complete rewrite.
I note, however, your tip to create a single STRDS for each band.
Thank for the magic,
Nikos
ps- Apologies for not finding the time to keep up with filing tickets in
trac, documenting stuff in our Wiki and be more participative.
* Sören Gebbert <soerengebbert@googlemail.com> [2017-10-24 12:56:43 +0200]:
Hi Nikos,
Best regards
Sören
Hi Nikos,
Cheers, Nikos
Nikos Alexandris | Remote Sensing & Geomatics
GPG Key Fingerprint 6F9D4506F3CA28380974D31A9053534B693C4FB3
