[GRASS-dev] Is automatic compilation of addons currently working ?
At https://grass.osgeo.org/addons/grass7/logs/ I see "logs generated Mon, 29 Jan 2018".
This seems to lead to the fact that recently added addons are not in the list of addon manual pages...
Moritz
2018-03-13 10:22 GMT+01:00 Moritz Lennert <mlennert@club.worldonline.be>:
Jan 2018".
not sure why cronjobs stopped working. I run script manually for now.
But we need to investigate if the cronjobs starts to work. Basically
in less than 30min the logs/manual should be updated after each
grass_addons commit. Ma
Martin Landa
http://geo.fsv.cvut.cz/gwiki/Landa
http://gismentors.cz/mentors/landa
On Tue, Mar 13, 2018 at 11:20 AM, Martin Landa <landa.martin@gmail.com> wrote:
Jan 2018".
(FWIW, here is the procedure
https://trac.osgeo.org/grass/browser/grass-addons/tools/addons/README.txt
Perhaps a change in the trac server does no longer trigger the job at your end?
On 13/03/18 11:20, Martin Landa wrote:
Jan 2018".
Great, thanks ! Will try to keep an eye on it.
Moritz
