[GRASS-dev] Is libjpeg actually used?
Dear developers!
REQUIREMENTS.html mentions libjpeg as a requirement for Grass,
specifically for r.out.tiff. The configure script will exit if no
libjpeg is present.
On the other hand, the final libraries are not linked to libjpeg and I
couldn't find a reference in the code.
Is libjpeg still required?
Greetings,
Volker Fröhlich
libjpeg is present.
No, and I'm not sure that it has ever actually been required. In all
probability, the test was a workaround for someone with a version of
libtiff which lacked dependency information. None of the Makefiles or
*.make files use any of JPEGINCPATH, JPEGLIBPATH or JPEGLIB. The last
two are used within configure.in as optional dependencies for libtiff
in the event that the check with -ltiff alone fails.
Everything related to JPEG should be removed from configure.in. The
TIFF check should simply add -ljpeg as an optional dependency, i.e.:
-LOC_CHECK_LIBS(tiff,TIFFOpen,TIFF,$TIFF_LIBRARY_DIRS,TIFFLIB,$JPEGLIBPATH $JPEGLIB,$ZLIB,$MATHLIB)
+LOC_CHECK_LIBS(tiff,TIFFOpen,TIFF,$TIFF_LIBRARY_DIRS,TIFFLIB,-ljpeg,$ZLIB,$MATHLIB)
If additional library directories are required for libjpeg, they can
be added via the --with-tiff-libs= option. Additional header
directories will never be required (the TIFF headers don't include the
JPEG headers).
Is somebody taking care of this or interested to do so? If not I'll file
a ticket.
Volker
> libjpeg is present.
JPEG headers).
a ticket.
I have fixed it in SVN (6.4, 6.5 and 7).
> a ticket.
Thank you! The reference in REQUIREMENTS.html is still left.
Volker
> a ticket.
Good catch, fixed.
I also updated
http://grass.osgeo.org/wiki/Compile_and_Install
http://grass.osgeo.org/wiki/Compile_and_Install/id
http://grass.osgeo.org/wiki/Compiling_on_MacOSX
