I was trying to check if r.in.wms works on G7. I’ve tried to download from the pcn [1] but it seems not working, anyone has experienced this?
BTW, I’ve tried also the examples from the manual page:
Disclaimer: The views expressed are purely those of the writer and may not in any circumstance be regarded as stating an official position of the European Commission.
r.in.wms mapserver=http://watzmann-geog.urz.uni-heidelberg.de/cached/osm layers=osm_auto:all output=osm format=png srs=900913
Downloading data from WMS server…
Reprojecting raster…
Importing raster map into GRASS…
ERROR: Sorry, is not a valid parameter
ERROR: r.mask failed
ERROR: No existing MASK to remove
Exception SystemExit: 1 in <bound method WMSGdalDrv.del of <wms_gdal_drv.WMSGdalDrv instance at 0x1b60050>> ignored
The other OSM example on the manual page is yet not working for me, maybe
should be changed/removed?
Well, I have added them recently (provided by Stepan) They worked
nicely. Please check g.region first.
But I fully agree that a reasonable g.region setting should be added to
the examples.
the examples.
btw, Stepan recently implemented experimental support for WMS in wxGUI [1].
the examples.
ciao
Margherita DI LEO
Postdoctoral Researcher
European Commission - DG JRC
Institute for Environment and Sustainability (IES). Unit H03 – FRC
Via Fermi, 2749
I-21027 Ispra (VA) - Italy - TP 261
2013/2/2 Margherita Di Leo <dileomargherita@gmail.com>:
Thank you Markus,
Hi Madi,
On Sat, Feb 2, 2013 at 8:01 PM, Markus Neteler <neteler@osgeo.org> wrote:
On Sat, Feb 2, 2013 at 7:41 PM, Margherita Di Leo
<dileomargherita@gmail.com> wrote:
> Thank you Rashad, it was simply slow, now managed to download with:
All three of the services listed (NASA and 2 OSM) give: “Unable to connect”.
It would be nice to have the possibility to expand a window showing the result of the “verbose” mode, in order to understand the problem.
2013/2/3 Margherita Di Leo <dileomargherita@gmail.com>:
All three of the services listed (NASA and 2 OSM) give: "Unable to
connect".
result of the "verbose" mode, in order to understand the problem.
make sense to me. Stepan could you take a look on this issue? Thanks, Martin
connect".
