We used the tutorial in grass=promo/tuorials/grassstarter, the script at the
end essentially, running on >Spearfish dataset.
hopefully found the right cmds (easier would be posting directly the
commands here).
workflow here in winGRASS7.4.0:
r.buffer input=streams@PERMANENT output=bstreams500 distances=500
r.null map=bstreams500@yann null=0
r.buffer input=roads@PERMANENT output=broads500 distances=500
r.null map=broads500@yann null=0
r.mapcalc expression="rbstreams500 = if( bstreams500@yann == 2, 1, 0)"
r.info map=slope@PERMANENT
| Range of data: min = 0 max = 52.52016
r.mapcalc expression="s_sl = if( rbstreams500@yann == 1, if( slope <= 5, 2,
5), 0)"
This expression will fail, note that the lack of quote is intentional, as
it is a requirement to run simpler >r.mapcalc statements in WinGRASS.
r.info map=s_sl@yann
| Map: s_sl@yann Date: Sun Feb 18 23:14:50 2018
| Mapset: yann Login of Creator: hkmyr
| DataBase: D:\grassdata
| Title: s_sl
| Timestamp: none
| Type of Map: raster Number of Categories: 0
| Data Type: CELL
| Rows: 466
| Columns: 633
| Total Cells: 294978
| Projection: UTM (zone 13)
| N: 4928000 S: 4914020 Res: 30
| E: 609000 W: 590010 Res: 30
| Data Description:
| generated by r.mapcalc
| Comments:
| if(rbstreams500@yann == 1, if(slope <= 5, 2, 5), 0)
r.stats -c -n input=s_sl@yann
0 109746
2 41812
5 140733
what should be the expected result of your calculations? are these different
to my calculations in winGRASS7.4.0.
a well described workflow and expected results would be helpfull for testing
if winGRASS 7.4.0 really fails here?
best regards
Helmut
Sent from: http://osgeo-org.1560.x6.nabble.com/Grass-Dev-f3991897.html
