while we meanwhile use GRASS GIS 7.6.svn in docker for months we ran
into this issue today:
root@52e6935c3247:/grassdb# grass76 --text c 'EPSG:4326'
/actinia_core/grassdb/latlongtest
Cleaning up temporary files...
Starting GRASS GIS...
Creating new GRASS GIS location <latlongtest>...
File "/usr/local/bin/grass76", line 2162, in <module>
main()
File "/usr/local/bin/grass76", line 2075, in main
geofile=params.geofile, create_new=True)
File "/usr/local/bin/grass76", line 1005, in set_mapset
create_location(gisdbase, location_name, geofile)
File "/usr/local/bin/grass76", line 807, in create_location
epsg=epsg, datum_trans=datum_trans)
File "/usr/local/grass-7.6.svn/etc/python/grass/script/core.py",
line 1538, in create_location
encoding='utf-8', mode='w')
File "/usr/lib/python2.7/codecs.py", line 898, in open
file = __builtin__.open(filename, mode, buffering)
IOError: [Errno 2] No such file or directory:
'/actinia_core/grassdb/latlongtest/PERMANENT/MYNAME'
... why that?
root@52e6935c3247:/grassdb# set | grep -i utf
LANG=C.UTF-8
LC_ALL=en_US.UTF-8
The directory is writable (I can mkdir the entire path without issues).
On Fri, Nov 9, 2018 at 6:39 PM Markus Neteler <neteler@osgeo.org> wrote:
root@52e6935c3247:/grassdb# grass76 --text c ‘EPSG:4326’
Cleaning up temporary files…
Starting GRASS GIS…
Creating new GRASS GIS location …
File “/usr/local/bin/grass76”, line 2162, in
main()
File “/usr/local/bin/grass76”, line 2075, in main
File “/usr/local/bin/grass76”, line 1005, in set_mapset
File “/usr/local/bin/grass76”, line 807, in create_location
File “/usr/local/grass-7.6.svn/etc/python/grass/script/core.py”,
encoding=‘utf-8’, mode=‘w’)
File “/usr/lib/python2.7/codecs.py”, line 898, in open
file = builtin.open(filename, mode, buffering)
‘/actinia_core/grassdb/latlongtest/PERMANENT/MYNAME’
… why that?
LANG=C.UTF-8
LC_ALL=en_US.UTF-8
I wonder what I should look for here?
For the open() to create MYNAME (mode is w), /actinia_core/grassdb/latlongtest/PERMANENT/ needs to exist already. Without looking to the source code, I assume that create_location() is creating …/latlongtest/PERMANENT directories (I don’t expect it actually tests if it was successful unless the underlying Python function checks that).
If /actinia_core/grassdb/ is a volume, I would try the same in a directory which is not a volume. Creating minimal reproducible example would be my next step, naive, but could help.
Am Sa., 10. Nov. 2018, 04:39 hat Vaclav Petras <wenzeslaus@gmail.com> geschrieben:
Starting GRASS GIS…
main()
… why that?
LANG=C.UTF-8
LC_ALL=en_US.UTF-8
It is a volume outside the docker and mounted inside.
The same docker image [1] doesn’t show this behavior on a different machine.
