On Jan 2, 2010, at 10:00 AM, grass-dev-request@lists.osgeo.org wrote:
Date: Sat, 2 Jan 2010 15:48:08 +0100
Subject: Re: [GRASS-dev] Issues of 6.5 build on WinXP
To: Jan To?ovsk? <j.tosovsky@tiscali.cz>
Cc: grass-dev@lists.osgeo.org
Message-ID:
<f8fe65c41001020648o5ecb5878l88084ad793d2267b@mail.gmail.com>
Content-Type: text/plain; charset=ISO-8859-2Hi,
2009/12/28 Jan To?ovsk? <j.tosovsky@tiscali.cz>:
1) I cannot add a new vector map layer. Only a dummy one is added without
the standard option dialog. All corresponding messages from the Command
output tab can be found at the bottom of this e-mail. Raster maps are Ok.I commented out problematic code in r40191. Now should work.
Martin
Glynn, Jan,
Do these changes and those in r40191-40200 fix the lag on adding a vector? Can you check?
Thanks
Michael
