[GRASS-dev] issues with compiling and running GRASS on Mac
I just updated from develbranch_6 after a couple of weeks. Here are some remaining problems in compiling and a showstopper with running GRASS.
1) vdigit: compiles fine now. BUT it probably keeps the wxPython GUI from running now (see below).
2) wxnviz: still doesn't compile but gets a bit farther if render.h is removed and make clean, make is run. Here is the error I get now.
cd /Users/cmbarton/grass_dev/grass6_src/lib/nviz
make
/Frameworks/UnixImageIO.framework/unix/include -I/Users/cmbarton/grass_dev/grass6_src/dist.i386-apple-darwin9.4.0/include -o OBJ.i386-apple-darwin9.4.0/render.o -c render.c
render.c: In function ‘Nviz_create_render_window’:
render.c:139: warning: assignment makes pointer from integer without a cast
render.c:146: warning: assignment makes pointer from integer without a cast
render.c: In function ‘Nviz_make_current_render_window’:
render.c:204: error: ‘mac_win’ undeclared (first use in this function)
render.c:204: error: (Each undeclared identifier is reported only once
render.c:204: error: for each function it appears in.)
render.c:204: warning: ‘AGLDrawable’ is deprecated
make: *** [OBJ.i386-apple-darwin9.4.0/render.o] Error 1
3) i.attcorr no longer compiles. Here is the error.
cmb-MBP-2:nviz cmbarton$ cd /Users/cmbarton/grass_dev/grass6_src/imagery/i.atcorr
cmb-MBP-2:i.atcorr cmbarton$ make
Makefile:15: warning: overriding commands for target `/Users/cmbarton/grass_dev/grass6_src/dist.i386-apple-darwin9.4.0/bin/i.atcorr'
../../include/Make/Module.make:14: warning: ignoring old commands for target `/Users/cmbarton/grass_dev/grass6_src/dist.i386-apple-darwin9.4.0/bin/i.atcorr'
c++ -I/Users/cmbarton/grass_dev/grass6_src/dist.i386-apple-darwin9.4.0/include -arch i386 -Os -g -DPACKAGE=\""grassmods"\" -I/Users/cmbarton/grass_dev/grass6_src/dist.i386-apple-darwin9.4.0/include -o OBJ.i386-apple-darwin9.4.0/main.o -c main.cpp
main.cpp: In function ‘void process_raster(int, InputMask, ScaleRange, int, int, int, bool, ScaleRange, bool)’:
main.cpp:309: error: ‘isnan’ was not declared in this scope
make: *** [OBJ.i386-apple-darwin9.4.0/main.o] Error 1
4) After make install, GRASS will no longer start up in wxPython. It does the startup screen fine, but bombs when it tries to launch the main layer manager. Here is the error:
GRASS 6.4.svn (Spearfish60_test):~ > Fatal Python error: Interpreter not initialized (version mismatch?)
Note that I have changed nothing on my system since the last time it compiled and ran fine.
I suspect that an issue that William Kyngesbury recently mentioned may be the cause. vdigit, which compiles now, may do so incorrectly against the system version of Python (2.5.1) rather than the newer one that is my Python default (2.5.2). If so, the version check in the wxGUI startup kills it.
What is the easiest way to diable vdigit to test this?
Michael
Forgot to mention that I tried compiling wxnviz WITH render.h and got the same errors.
Michael
make
I disabled the vdigit makefile so that it raised and error and didn’t compile. I still get the same error:
Any idea what is causing this if I have not changed Python or wxPython on my Mac since this last compiled with no problem (25 August).
Michael
Begin forwarded message:
Date: September 7, 2008 8:47:57 PM GMT-07:00
To: Landa Martin <landa.martin@gmail.com>, grass developers <grass-dev@lists.osgeo.org>, Kyngesburye William <kyngchaos@kyngchaos.com>
Subject: issues with compiling and running GRASS on Mac
  1. vdigit: compiles fine now. BUT it probably keeps the wxPython GUI from running now (see below).
  2. wxnviz: still doesn’t compile but gets a bit farther if render.h is removed and make clean, make is run. Here is the error I get now.
make
  1. i.attcorr no longer compiles. Here is the error.
Makefile:15: warning: overriding commands for target /Users/cmbarton/grass_dev/grass6_src/dist.i386-apple-darwin9.4.0/bin/i.atcorr' ../../include/Make/Module.make:14: warning: ignoring old commands for target /Users/cmbarton/grass_dev/grass6_src/dist.i386-apple-darwin9.4.0/bin/i.atcorr’
c++ -I/Users/cmbarton/grass_dev/grass6_src/dist.i386-apple-darwin9.4.0/include -arch i386 -Os -g -DPACKAGE="“grassmods”" -I/Users/cmbarton/grass_dev/grass6_src/dist.i386-apple-darwin9.4.0/include -o OBJ.i386-apple-darwin9.4.0/main.o -c main.cpp
  1. After make install, GRASS will no longer start up in wxPython. It does the startup screen fine, but bombs when it tries to launch the main layer manager. Here is the error:
Michael
After some tedious detective work, the startup error in wxGUI is caused by the following line in vdigit.py
import _grass6_wxvdigit
This calls _grass6_wxvdigit.so
So back to my first guess, vdigit is compiling with a different version of Python than the rest of GRASS.
Michael
Michael
make
Michael
main.cpp:309: error: �isnan� was not declared in this scope
isnan() isn't part of the C++ standard. It may be provided as an
extension by some versions of gcc, or it may not.
I don't know about the easiest way, but the only robust solution is to
keep nagging the wxGUI developers until they move the high-risk
features (vdigit, nviz) out of the main wxGUI process.
2008/9/8 Glynn Clements <glynn@gclements.plus.com>:
it's my plan, I started to elaborate with NvizThread in nviz_mapdisp.py...
M.
Martin Landa <landa.martin gmail.com> * http://gama.fsv.cvut.cz/~landa *
disable render.c, not .h.
Michael
William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
http://www.kyngchaos.com/
"This is a question about the past, is it? ... How can I tell that the past isn't a fiction designed to account for the discrepancy between my immediate physical sensations and my state of mind?"
- The Ruler of the Universe
Er, how does that help?
For nviz/vdigit extension, there two main points I would like to fix:
* when extension crash (G_fatal_error is called) to avoid crashing whole GUI
* redirect message printed by extension to stdout, strderr to Layer
Manager "Command Area" (goutput.py)
NvizThread class maybe can help in this effort (?)
Thanks for any pointer in advance, Martin
Using another thread won't help protect against errors which occur
within C code; for that, you need a completely separate process.
Threads just allow for concurrent execution; they don't provide
isolation.
exit() (as used by G_fatal_error()) terminates the process, not just
the thread. Likewise for fatal signals (e.g. SIGSEGV).
OTOH, A separate thread will help protect against Python exceptions,
which only terminate the thread which raised the exception.
Essentially, vdigit and nviz need to be separate applications. They
can "import" as many wxGUI modules as they want, but any sharing of
data between them and the main wxGUI process will require explicit
communication between the processes.
I'm aware that this results in either reduced usablity or increased
complexity (or some compromise between the two), but it's the only way
to ensure that an error in vdigit/nviz (or rather, in the C code which
they call) only terminates that component rather than the entire GUI.
