shall we keep or remove r.resample in GRASS 7?
Its functionality is replaced by "r.resamp.interp method=nearest", or
if you wish to match old r.resample method exactly*: "r.mapcalc new=old".
[*] IIRC
Hamish
[*] IIRC
Hamish
if you wish to match old r.resample method exactly*: "r.mapcalc new=old".[*] IIRC
I suggest to remove it.
We should also do several name changes, see
http://grass.osgeo.org/wiki/GRASS_7_ideas_collection#rename
http://grass.osgeo.org/wiki/GRASS_7_ideas_collection#rename_2
> [*] IIRCI suggest to remove it.
Or replace it with a script:
#!/usr/bin/env python
# [option declarations snipped]
import grass
def main():
input = options['input']
output = options['output']
grass.run_command('r.mapcalc', expr = '"%s" = "%s"' % (input, output))
if __name__ == "__main__":
options, flags = grass.parser()
main()
OTOH, it may be worth keeping simply as an example of a raster module.
