[GRASS-dev] latest snapshot G7 crashes on windows 7
Hi!
today with a friend we tried to install the latest snapshot of G7 on windows 7 on his computer. The installation went apparently smooth, but eventually at the start the program crashed. Since I don’t have idea on where to check for error logs in windows I wasn’t able to check the error in order to report it properly, and also the black window appeared for a fraction of second and disappeared. Any idea on where to look for hints?
Thanks in advance.
Best regards,
Margherita DI LEO
Postdoctoral Researcher
European Commission - DG JRC
Institute for Environment and Sustainability (IES)
Via Fermi, 2749
I-21027 Ispra (VA) - Italy - TP 261
Tel. +39 0332 78 3600
margherita.di-leo@jrc.ec.europa.eu
Disclaimer: The views expressed are purely those of the writer and may not in any circumstance be regarded as stating an official position of the European Commission.
Margherita:
the program crashed. Since I don't have idea on where
to check for error logs in windows I wasn't able to
I just tested grass7 with the latest nightly snapshot on XP, starts
ok for me.
if you open a cmd.exe window, and right click -> properties on the
desktop icon, at the C:\> prompt do a little cut and paste to
cd into the startup dir, then cut and paste the "target" startup
command.
then when it fails you get a chance to see the error without the
window disappearing.
Hamish
