[GRASS-dev] launch i.class from Wxpython in GRASS6.4
Hi all
I tried to run i.class in GRASS6.4 for UBUNTU, from Wxpython menu and it doesn't launch anything. If I recall a some past emails, I have to use d.mon x0 and then i.class right? Or can I call d.mon x0 from a GRASS-Script?
Is it planned to fix this issue for GRAS6.4?
And Is it fixed in GRASS6.5 or GRASS7 versions?
Thank you
Antonio
__________ Information from ESET NOD32 Antivirus, version of virus signature database 5030 (20100415) __________
The message was checked by ESET NOD32 Antivirus.
http://www.eset.com
2010/4/15 António Rocha <antonio.rocha@deimos.com.pt>:
using fresh GRASS 6.4 from SVN, i.class starts from the menu without
problem. Are you using RCs?
Martin
Martin Landa <landa.martin gmail.com> * http://gama.fsv.cvut.cz/~landa
YOu are absolutely right. I meant when I insert i.class in GRASS GIS layer manager Command line it opens a Menu but nothing happens. DOes the same thing happens in 6.5 or GRASS7?
By the way, I tried to use i.class and I got a output signature file a bit of incomplete:
#A
2565
#A
2565
#C
3500
#C
7351
#F
5381
What might be happening?
Thank you Martin
Martin Landa wrote:
Martin
http://www.eset.com
