I would like the SQL 'LIKE' to be functional for the
dbf driver. While '~' is working, 'LIKE' is rejected.
I assume (also tried a bit) that 'LIKE' needs to be
mapped to '~' (COMPARISON_OPERATOR, SQL_MTCH) to be passed
on to the dbf driver.
I didn't manage to implement it right in lib/db/sqlp.
Ideas?
Markus Neteler wrote:
Ideas?
I would think that adding:
[Ll][Ii][Kk][Ee] {
yylval.strval = (char*)strdup("~");
return COMPARISON_OPERATOR;
to lib/db/sqlp/lex.l should suffice.
> Hi,
> Ideas?
[Ll][Ii][Kk][Ee] {
Works, thanks.
The DBF driver now understands (sort of) 'LIKE'.
Unfortunately the behaviour isn't yet PostgreSQL compliant:
PostgreSQL says:
'abc' LIKE 'abc' true
'abc' LIKE 'a%' true
'abc' LIKE '_b_' true
'abc' LIKE 'c' false
GRASS DBF driver now does:
GRASS 6.1.cvs (pat):~ > v.db.select meteo_stations where="station LIKE 'P0'"
cat|station|east|north
93|P01|1653952|5061546
94|P02|1649511|5063172
95|P03|1640450|5098211
GRASS 6.1.cvs (pat):~ > v.db.select meteo_stations where="station LIKE 'P__'"
GRASS 6.1.cvs (pat):~ > v.db.select meteo_stations where="station LIKE 'P%'"
GRASS 6.1.cvs (pat):~ > v.db.select meteo_stations where="station LIKE 'P'"
I don't know where the pattern matching is done for the DBF
driver (db/drivers/dbf/?).
> > Ideas?
> [Ll][Ii][Kk][Ee] {
Works, thanks.
The actual DBF implementation is in db/drivers/dbf/dbfexe.c.
The LIKE operator (SQLP_MTCH) is simply the strstr() function, i.e. it
indicates whether the RHS is a substring of the LHS.
Efficiently implementing correct semantics for patterns which contain
more than one % is non-trivial.
For a single %, the easiest approach is to match from both ends, i.e.
check that the beginning of the string matches the part before the %,
the end of the string matches the part after the %, and the two parts
don't overlap (the last part is necessary so that 'abc' LIKE 'ab%bc'
is false).
