On Jan 28, 2008, at 8:32 AM, grass-dev-request@lists.osgeo.org wrote:
Date: Mon, 28 Jan 2008 04:30:21 -0800 (PST)
Subject: [GRASS-dev] lib fn to convert int color number to RGB values?
To: grass-dev@lists.osgeo.org
Message-ID: <16992.67894.qm@web45802.mail.sp1.yahoo.com>
Content-Type: text/plain; charset=iso-8859-1Hi,
I am looking for a library function to get the R,G,B values (0-255) for
an integer color number which was created with D_parse_color(). I don't
want to set the color for drawing, just get the RGB component values so
I can populate a RGBA_Color struct. Reparsing the original color string
isn't an option without a lot of re-fn prototyping as I'm operating in
a subordinate function with only the int color number available.I've searched through the color functions in the display, raster, and
gis libraries without much luck. The closest I found was
D_raster_use_color().any ideas?
Is a new D_number_to_RGB(int color, unsigned char &r,&g,&b) fn needed
in lib/display/tran_colr.c? Or some place better?thanks,
Hamish
We have such functions in both the TclTk and wxPython GUI's if that is any help.
Michael
