cd lib/form/
make
gcc -I/home/guest/rpm/BUILD/grass-6.4/dist.i686-pc-linux-gnu/include
-g -O2 -fPIC -DPACKAGE=\""grasslibs"\"
-I/home/guest/rpm/BUILD/grass-6.4/dist.i686-pc-linux-gnu/include -o
OBJ.i686-pc-linux-gnu/form.o -c form.c
form.c: In function 'submit':
form.c:195: error: 'Tcl_Interp' has no member named 'result'
make: *** [OBJ.i686-pc-linux-gnu/form.o] Error 1
Hello,
there was similar issue reported on Mac. It comes from tcl.h where
they recommend not to use result:
463 typedef struct Tcl_Interp {
464 /* TIP #330: Strongly discourage extensions from using the
string result. */
465 #ifdef USE_INTERP_RESULT
I'm not a make process guru to propose solution.
Maris.
2009/1/20, Markus Neteler <neteler@osgeo.org>:
hi,
I tried to compile GRASS on Mandriva Cooker which comes (currently)
with
cd lib/form/
make
On Tue, Jan 20, 2009 at 11:20 AM, Maris Nartiss <maris.gis@gmail.com> wrote:
Hello,
string result. */
Yes, it is
In short - no one has eliminated old tcl/tk versions out there. Any
patch needs to work with old and new approach too. Also forms isn't
the only place where interp result is used (lazy to grep)
Maris.
2009/1/21 Markus Neteler <neteler@osgeo.org>:
Hello,
string result. */
On Wed, Jan 21, 2009 at 5:58 PM, Maris Nartiss <maris.gis@gmail.com> wrote:
Yes, it is
This is the list:
./lib/form/form.c
./vector/v.digit/form.c
./visualization/nviz/src/anim_support.c
./visualization/nviz/src/cutplane_obj.c
./visualization/nviz/src/do_zoom.c
./visualization/nviz/src/draw.c
./visualization/nviz/src/exag.c
./visualization/nviz/src/lights.c
./visualization/nviz/src/map_obj.c
./visualization/nviz/src/misc.c
./visualization/nviz/src/mkdspf_main.c
./visualization/nviz/src/nvizAppInit.c
./visualization/nviz/src/nviz_init.c
./visualization/nviz/src/position.c
./visualization/nviz/src/togl_flythrough.c
./visualization/nviz/src/volume.c
I am willing to fix it if someone tells me how.
The lack of ./lib/form/form.c fix breaks some more modules,
so that's of priority.
This is the list:
./lib/form/form.c
Hello,
string result. */
What do you need? I have added TCL_VERSION to
configure which is now set as well.
In IRC, #tcl channel they suggested
Tcl_GetString(Tcl_GetObjResult(interp))
to me.
