What is the intent of this change?
--- lib/init/grass.py (revision 37898)
+++ lib/init/grass.py (revision 37899)
@@ -591,9 +591,10 @@
# Check for gui interface
if grass_gui == "wxpython":
- call([os.getenv('GRASS_PYTHON'),
- gfile("etc", "wxpython", "wxgui.py")])
+ subprocess.Popen([os.getenv('GRASS_PYTHON'),
+ gfile("etc", "wxpython", "wxgui.py")],
+ stdout=subprocess.PIPE)
Using subprocess.PIPE when nothing can read from the pipe is a bug.
If output should go to the terminal, stdout shouldn't be set. If
output should be discarded, use os.devnull (see check_gui for example
usage).
2009/6/18 Glynn Clements <glynn@gclements.plus.com>:
to run wxgui.py on the background, otherwise GRASS prompt is started
after closing wxGUI.
\# Check for gui interface
if grass\_gui == "wxpython":
usage).
Done in r37930.
Martin
Martin Landa <landa.martin gmail.com> * http://gama.fsv.cvut.cz/~landa
