[GRASS-dev] lib/vector/Vlib/*.c: Too much uses of `GRASS_VECT_DIRECTORY'
  May I suggest the change below?
  Basically, this one introduces three tiny new functions to be
  used instead of coding the construction of the vector
  map-related filenames explicitly. Like:
- sprintf (buf, "%s/%s", GRASS_VECT_DIRECTORY, map_info->name);
+ Vect_map_file_name_rel (buf, map_info);
  I wasn't sure where to declare these functions, so I've added
  the prototypes to `include/Vect.h'.
Index: include/Vect.h
--- include/Vect.h (revision 36440)
+++ include/Vect.h (working copy)
@@ -218,6 +218,13 @@
int Vect_rewind(struct Map_info *);
int Vect_close(struct Map_info *);
+/* filenames */
+int Vect_map_file_name_rel (char [GPATH_MAX], const struct Map_info *);
+int Vect_map_element_file_name_rel (char [GPATH_MAX],
+ const struct Map_info *, const char *);
+int Vect_map_element_file_name_abs (char [GPATH_MAX],
/* Read/write lines, nodes, areas */
/* Level 1 and 2 */
int Vect_read_next_line(struct Map_info *, struct line_pnts *,
Index: lib/vector/Vlib/file_name.c
--- lib/vector/Vlib/file_name.c (revision 0)
+++ lib/vector/Vlib/file_name.c (revision 0)
@@ -0,0 +1,48 @@
+ \file file_name.c
+ \brief GIS library - Determine GRASS data base / vector file name
+ (C) 2009 by the GRASS Development Team
+ This program is free software under the GNU General Public License as
+ published by the Free Software Foundation; either version 2 of the
+ License, or (at your option) any later version.
+ Read the file COPYING that comes with GRASS
+ for details.
+#include <string.h>
+#include <grass/gis.h>
+#include <grass/Vect.h>
+int
+Vect_map_file_name_rel (char result[GPATH_MAX],
+ const struct Map_info *map)
+ return
+ sprintf (result, "%s/%s",
+ GRASS_VECT_DIRECTORY, map->name);
+int
+Vect_map_element_file_name_rel (char result[GPATH_MAX],
+ const struct Map_info *map,
+ const char *element)
+ return
+ sprintf (result, "%s/%s/%s",
+ GRASS_VECT_DIRECTORY, map->name, element);
+int
+Vect_map_element_file_name_abs (char result[GPATH_MAX],
+ return
+ sprintf (result, "%s/%s/%s/%s/%s/%s",
+ map->gisdbase, map->location, map->mapset,
Index: lib/vector/Vlib/build.c
--- lib/vector/Vlib/build.c (revision 36440)
+++ lib/vector/Vlib/build.c (working copy)
@@ -247,7 +247,7 @@
     plus = &(Map->plus);
     /* write out all the accumulated info to the plus file */
- sprintf(buf, "%s/%s", GRASS_VECT_DIRECTORY, Map->name);
+ Vect_map_file_name_rel (buf, Map);
     G__file_name(fname, buf, GV_TOPO_ELEMENT, Map->mapset);
     G_debug(1, "Open topo: %s", fname);
     dig_file_init(&fp);
@@ -398,7 +398,7 @@
     /* write out rtrees to the sidx file */
     G__file_name(fname, buf, GV_SIDX_ELEMENT, Map->mapset);
     G_debug(1, "Open sidx: %s", fname);
     dig_file_init(&fp);
Index: lib/vector/Vlib/close.c
--- lib/vector/Vlib/close.c (revision 36440)
+++ lib/vector/Vlib/close.c (working copy)
@@ -77,7 +77,7 @@
   struct stat info;
   /* Delete old support files if available */
   G__file_name(file_path, buf, GV_TOPO_ELEMENT, G_mapset());
   if (stat(file_path, &info) == 0) /* file exists? */
Index: lib/vector/Vlib/open_nat.c
--- lib/vector/Vlib/open_nat.c (revision 36440)
+++ lib/vector/Vlib/open_nat.c (working copy)
@@ -49,7 +49,7 @@
     G_debug(1, "V1_open_old_nat(): name = %s mapset = %s", Map->name,
       Map->mapset);
     dig_file_init(&(Map->dig_fp));
     if (update)
   Map->dig_fp.file = G_fopen_modify(buf, GRASS_VECT_COOR_ELEMENT);
Index: lib/vector/Vlib/close_ogr.c
--- lib/vector/Vlib/close_ogr.c (revision 36440)
+++ lib/vector/Vlib/close_ogr.c (working copy)
@@ -73,7 +73,7 @@
     if (strcmp(Map->mapset, G_mapset()) == 0 && Map->support_updated &&
   Map->plus.built == GV_BUILD_ALL) {
- sprintf(elem, "%s/%s", GRASS_VECT_DIRECTORY, Map->name);
+ Vect_map_file_name_rel (elem, Map);
   G__file_name(fname, elem, "fidx", Map->mapset);
   G_debug(4, "Open fidx: %s", fname);
   dig_file_init(&fp);
Index: lib/vector/Vlib/cindex.c
--- lib/vector/Vlib/cindex.c (revision 36440)
+++ lib/vector/Vlib/cindex.c (working copy)
@@ -451,7 +451,7 @@
     G__file_name(fname, buf, GV_CIDX_ELEMENT, Map->mapset);
     G_debug(2, "Open cidx: %s", fname);
     dig_file_init(&fp);
@@ -497,7 +497,7 @@
     Plus = &(Map->plus);
     G__file_name(file_path, buf, GV_CIDX_ELEMENT, Map->mapset);
     if (stat(file_path, &info) != 0) /* does not exist */
Index: lib/vector/Vlib/open_ogr.c
--- lib/vector/Vlib/open_ogr.c (revision 36440)
+++ lib/vector/Vlib/open_ogr.c (working copy)
@@ -122,7 +122,7 @@
     G_debug(3, "V2_open_old_ogr()");
     dig_file_init(&fp);
     fp.file = G_fopen_old(elem, "fidx", Map->mapset);
     if (fp.file == NULL) {
Index: lib/vector/Vlib/field.c
--- lib/vector/Vlib/field.c (revision 36440)
+++ lib/vector/Vlib/field.c (working copy)
@@ -603,9 +603,7 @@
           Map->format);
- sprintf(file, "%s/%s/%s/%s/%s/%s", Map->gisdbase, Map->location,
- Map->mapset, GRASS_VECT_DIRECTORY, Map->name,
- GRASS_VECT_DBLN_ELEMENT);
+ Vect_map_element_file_name_abs (file, Map, GRASS_VECT_DBLN_ELEMENT);
     G_debug(1, "dbln file: %s", file);
     fd = fopen(file, "r");
@@ -676,9 +680,7 @@
     dbl = Map->dblnk;
     fd = fopen(file, "w");
Index: lib/vector/Vlib/header.c
--- lib/vector/Vlib/header.c (revision 36440)
+++ lib/vector/Vlib/header.c (working copy)
@@ -88,7 +88,7 @@
     char buf[200];
     FILE *head_fp;
     head_fp = G_fopen_new(buf, GRASS_VECT_HEAD_ELEMENT);
     if (head_fp == NULL) {
@@ -137,7 +137,7 @@
     Vect_set_thresh(Map, 0.);
     G_debug(1, "Vect__read_head(): vector = %s@%s", Map->name, Map->mapset);
- sprintf(buff, "%s/%s", GRASS_VECT_DIRECTORY, Map->name);
+ Vect_map_file_name_rel (buff, Map);
     head_fp = G_fopen_old(buff, GRASS_VECT_HEAD_ELEMENT, Map->mapset);
   G_warning(_("Unable to open header file of vector <%s>"),
FSF associate member #7257
If it's tested, at least I have no objections.
Not sure if it will give problems when char buf[200] is treated as char result[GPATH_MAX].
Just two remarks. First, please work with latest svn version which is r36445 since 2009-03-21 10:19:54 +0100 i.e. yesterday, because I'm also busy with the vector libs. Second, I have already changed G_find_file2 to G_find_vector2 in Vect_open_new.
Best regards,
Markus M
+/* filenames */
/* Level 1 and 2 */
@@ -0,0 +1,48 @@
+ \file file_name.c
+ for details.
+int
+ return
+int
+ return
+int
+ return
@@ -247,7 +247,7 @@
     dig_file_init(&fp);
@@ -398,7 +398,7 @@
     dig_file_init(&fp);
@@ -77,7 +77,7 @@
   struct stat info;
@@ -49,7 +49,7 @@
       Map->mapset);
     if (update)
@@ -73,7 +73,7 @@
   dig_file_init(&fp);
@@ -451,7 +451,7 @@
     dig_file_init(&fp);
@@ -497,7 +497,7 @@
@@ -122,7 +122,7 @@
     dig_file_init(&fp);
@@ -603,9 +603,7 @@
           Map->format);
@@ -676,9 +680,7 @@
      dbl = Map->dblnk;
@@ -88,7 +88,7 @@
     char buf[200];
     FILE *head_fp;
@@ -137,7 +137,7 @@
Markus Metz <markus.metz.giswork@googlemail.com> writes:
>> Basically, this one introduces three tiny new functions to be used
>> instead of coding the construction of the vector map-related
  Any ideas on how to perform the testing? I'm going to try to
  perform some operations on the vectors in my data sets, but I
  just can't think out anything better than that (to do in a
  reasonable time.)
  That's the problem of the already existing code, which is going
  to show up when someone will try to work with vector names
  longer than 192 characters. Obviously, 200 should be replaced
  with GPATH_MAX. That should be a separate patch.
  One reason behind these functions was to enable the compiler to
  recognize the errors like that and possibly emit a warning.
  ACK.
> Vect_open_new.
  ACK. Thanks.
  reasonable time.)
No better ideas here, but maybe some other developers have some ideas (apart from using very long vector names).
Interesting. Maybe fix that first because it is a potential bug, i.e. use GNAME_MAX, GMAPSET_MAX, and GPATH_MAX wherever appropriate? As I understand, your patch is an improvement but not a bugfix, so I would opt for fixing (potential) bugs first, then improve. Maybe wait for a second opinion, I'm still new here.
> Vect_open_new.
  ACK. Thanks.
I think it's better if I don't touch these parts anymore as long as you are busy with it, just to avoid confusion, and leave vector name handling to you.
Best regards,
Markus M
>> That's the problem of the already existing code, which is going to
>> show up when someone will try to work with vector names longer than
>> 192 characters. Obviously, 200 should be replaced with GPATH_MAX.
  It may make sense.
>>> Vect_open_new.
>> ACK. Thanks.
> handling to you.
  Actually, what I was going to work on is the /raster/ support.
  I've briefly scanned over the vector support code to get some
  clues, and spotted some rough places. Therefore, I don't think
  that I'll be doing much more work on the vector parts of the
  library anytime soon.
