I’ve installed GRASS 7.8.5 from new OSGeo4W installer [0], but when I run GRASS and try to start a new session I get:
Cleaning up temporary files...
D1/1: G_set_program_name(): clean_temp
D1/1: G_set_program_name(): db.connect
D1/1: Creating new default DB params with db_set_default_connection()
__________ ___ __________ _______________
/ ____/ __ \/ | / ___/ ___/ / ____/ _/ ___/
/ / __/ /_/ / /| | \__ \\_ \ / / __ / / \__ \
/ /_/ / _, _/ ___ |___/ /__/ / / /_/ // / ___/ /
\____/_/ |_/_/ |_/____/____/ \____/___//____/
Welcome to GRASS GIS 7.8.5
GRASS GIS homepage: [https://grass.osgeo.org](https://grass.osgeo.org)
This version running through: Command Prompt (C:\WINDOWS\system32\cmd.exe)
Help is available with the command: g.manual -i
See the licence terms with: g.version -c
See citation options with: g.version -x
If required, restart the GUI with: g.gui wxpython
When ready to quit enter: exit
Launching <wxpython> GUI in the background, please wait...
Microsoft Windows [Version 10.0.19042.804]
(c) 2020 Microsoft Corporation. Todos os direitos reservados.
C:\OSGeo4W64\bin>D1/1: G_set_program_name(): g.gisenv
D1/1: grass.script.core.start_command(): g.gisenv -n
wxnviz.py: Could not find module 'C:\OSGEO4~1\apps\grass\grass78\lib\libgrass_gis.7.8.dll' (or one of its dependencies). Try using the full path with constructor syntax.
wxdigit.py: Could not find module 'C:\OSGEO4~1\apps\grass\grass78\lib\libgrass_gis.7.8.dll' (or one of its dependencies). Try using the full path with constructor syntax.
File "C:\OSGEO4~1\apps\grass\grass78\gui\wxpython\wxgui.py", line 104, in OnInit
from lmgr.frame import GMFrame
File "C:\OSGEO4~1\apps\grass\grass78\gui\wxpython\lmgr\frame.py", line 51, in <module>
from lmgr.layertree import LayerTree, LMIcons
File "C:\OSGEO4~1\apps\grass\grass78\gui\wxpython\lmgr\layertree.py", line 38, in <module>
from mapdisp.frame import MapFrame
File "C:\OSGEO4~1\apps\grass\grass78\gui\wxpython\mapdisp\frame.py", line 43, in <module>
from mapwin.buffered import BufferedMapWindow
File "C:\OSGEO4~1\apps\grass\grass78\gui\wxpython\mapwin\buffered.py", line 52, in <module>
import grass.lib.gis as gislib
File "C:\OSGEO4~1\apps\grass\grass78\etc\python\grass\lib\gis.py", line 23, in <module>
_libs["grass_gis.7.8"] = load_library("grass_gis.7.8")
File "C:\OSGEO4~1\apps\grass\grass78\etc\python\grass\lib\ctypes_loader.py", line 62, in load_library
return self.load(path)
File "C:\OSGEO4~1\apps\grass\grass78\etc\python\grass\lib\ctypes_loader.py", line 240, in load
return _WindowsLibrary(path)
File "C:\OSGEO4~1\apps\grass\grass78\etc\python\grass\lib\ctypes_loader.py", line 223, in __init__
self.cdll = ctypes.cdll.LoadLibrary(path)
File "C:\OSGEO4~1\apps\Python39\lib\ctypes\__init__.py", line 452, in LoadLibrary
return self._dlltype(name)
File "C:\OSGEO4~1\apps\Python39\lib\ctypes\__init__.py", line 374, in __init__
self._handle = _dlopen(self._name, mode)
FileNotFoundError: Could not find module 'C:\OSGEO4~1\apps\grass\grass78\lib\libgrass_gis.7.8.dll' (or one of its dependencies). Try using the full path with constructor syntax.
OnInit returned false, exiting...
This seems to affect Windows 10 operating systems in locale languages, in this case, portuguese, where the issue is confirmed on 3 different machines.
I've reported it in OSGeo4W tracker [1], because I thought it was related to some kind of packaging issue, but I decided to post it here to get your opinions.
Thank you very much.
Best regards,
Pedro Venâncio
[0] [https://download.osgeo.org/osgeo4w/testing/](https://download.osgeo.org/osgeo4w/testing/)
[1] [https://trac.osgeo.org/osgeo4w/ticket/661](https://trac.osgeo.org/osgeo4w/ticket/661)
