Hi list -
I was trying to run r.terraflow after a clean build of 6.4 (LOVE the
GUI!!) , and it wasn't there...so went into raster/r.terraflow and tried
to make it. it is complaining because libgrass_iostream didn't get built.
Any --configure flags I should be setting?
I'm just building with:
./configure --with-gdal --with-tcktk-libs=/usr/lib/tk8.4
--with-tcltk-includes=/usr/include/tcl8.4/ --enable-largefile
thanks in advance!
Chris Nicholas
2009/10/9 <cgnicholas@alamedanet.net>:
error log could be useful otherwise it's hard to guess what is wrong...
Martin
Martin Landa <landa.martin gmail.com> * http://gama.fsv.cvut.cz/~landa
hmmm ... no errors; just doesn't look like it's even entering that dir,
and when I manually to build, nothing happens...sort of like it's #ifdef'd
out...hoping not to got on Makefile safari, but...whatever it takes!
Chris
cgn@maps:~/src/grass-6.4.0RC5$ cat error.log
GRASS GIS compilation log
Started compilation: Fri Oct 9 15:19:08 EDT 2009
Errors in:
No errors detected.
Finished compilation: Fri Oct 9 15:19:45 EDT 2009
cgn@maps:~/src/grass-6.4.0RC5$ cd lib/iostream
cgn@maps:~/src/grass-6.4.0RC5/lib/iostream$ make
cgn@maps:~/src/grass-6.4.0RC5/lib/iostream$ echo "nothing happened..
nothing happened..
cgn@maps:~/src/grass-6.4.0RC5/lib/iostream$ ls
ami_stream.cc Makefile mm.cc rtimer.cc
chrismake minmaxheap_test.cc mm_utils.cc
cgn@maps:~/src/grass-6.4.0RC5/lib/iostream$ cat Makefile
MODULE_TOPDIR = ../..
LIB_OBJS = mm.o mm_utils.o ami_stream.o rtimer.o
LIB_NAME = $(IOSTREAM_LIBNAME)
include $(MODULE_TOPDIR)/include/Make/Lib.make
ifneq ($(USE_LARGEFILES),)
EXTRA_CFLAGS = -D_FILE_OFFSET_BITS=64
endif
ifneq ($(strip $(CXX)),)
default: stlib
else
default:
endif
Ciao,
2009/10/10 <cgnicholas@alamedanet.net>:
default: stlib
else
default:
endif
right, you need to configure GRASS with
--with-cxx
since r.terraflow is a C++ module.
Martin
VOILA!!!!!!!!!!!
thanks!!!
Chris
(playing with the ASTER 30m DEMs ... and now terraflow!! ... time to learn
how to make a time-series, etc)
Ciao,
default: stlib
else
default:
endif
--with-cxx
Martin
Hmmm - perhaps not so fast...my tmp area is an ext3 file system, and I
compiled everything with --largefiles, etc....hmmmm
Chris
FILL: 20.28G (21780347904) [388934784 elements, 56B each]
file=/home/cgn/tmp//STREAM_EoACCO:cannot read!: Bad address
r.terraflow:
/home/cgn/src/grass-6.4.0RC5/dist.i686-pc-linux-gnu/include/grass/iostream/ami_sort_impl.h:91:
size_t makeRun_Block(AMI_STREAM<T>*, T*, unsigned int, Compare*) [with T =
keyvalue<int>, Compare = keyCmpKeyvalueType<int>]: Assertion `err ==
AMI_ERROR_NO_ERROR || err == AMI_ERROR_END_OF_STREAM' failed.
cgn@maps:~$ cd tmp
cgn@maps:~/tmp$ df -k .
Filesystem 1K-blocks Used Available Use% Mounted on
/dev/sda1 470148268 77855996 368410048 18% /
cgn@maps:~/tmp$
cgn@maps:~/tmp$ ls
STREAM_cYvU25 STREAM_J2CrzX STREAM_TXsdtt STREAM_Wgw7I0
STREAM_EoACCO STREAM_tFmbMn STREAM_UxXNFF STREAM_WH31Yx
cgn@maps:~/tmp$ ls -la
total 6604764
drwxr-xr-x 2 cgn cgn 4096 2009-10-09 19:29 .
drwxr-xr-x 65 cgn root 4096 2009-10-09 19:11 ..
-rw------- 1 cgn cgn 3642522012 2009-10-09 19:29 STREAM_cYvU25
-rw------- 1 cgn cgn 2644176 2009-10-09 19:29 STREAM_EoACCO
-rw------- 1 cgn cgn 1555739136 2009-10-09 19:13 STREAM_J2CrzX
-rw------- 1 cgn cgn 1555739136 2009-10-09 19:29 STREAM_tFmbMn
-rw------- 1 cgn cgn 0 2009-10-09 19:29 STREAM_TXsdtt
-rw------- 1 cgn cgn 0 2009-10-09 19:13 STREAM_UxXNFF
-rw------- 1 cgn cgn 0 2009-10-09 19:29 STREAM_Wgw7I0
-rw------- 1 cgn cgn 0 2009-10-09 19:29 STREAM_WH31Yx
OK - here are the particular...and thanks again folks for even looking at
this foo!!!
when the console output sez: "Will need at least 40.57G (43560695808)
space available in /home/cgn/tmp/ " that should not be a problem
whatsoever....there's 10x there available...
cgn@maps:~/tmp$ pwd
/home/cgn/tmp
/dev/sda1 470148268 84561668 361704376 19% /
cgn@maps:~/tmp$
So here's my region - the island of Hispanola, in UTM, using 30m ASTER
DEMs... (all this is just a warm-up for the inevitable hurricane and
subsequent flooding...)
projection: 1 (UTM)
south: 1879551.69903301
east: 1246672.22364716
ewres: 29.67282656
rows: 15456
cols: 25164
cells: 388934784
nsres: 29.67282656
west: 499985.21620627
zone: 0
datum: wgs84
ellipsoid: a=6378137 es=0.006694379990141316
north: 2338174.90627377
here's the command-line shtuff:
GRASS 6.4.0RC5 (Haiti):~/public_html/maps/Haiti > r.terraflow
elevation=DEM@OCHA filled=flooded direction=flow_direction
swatershed=sink_watershed accumulation=flow_accum
tci=topo_convergence_index d8cut=infinity memory=1000
STREAM_DIR=/home/cgn/tmp/ stats=stats.out --overwrite memory=1200
WARNING: raster DEM is of type CELL_TYPE --you should use r.terraflow.short
STREAM temporary files in /home/cgn/tmp/ (THESE INTERMEDIATE STREAMS WILL
NOT BE DELETED IN CASE OF ABNORMAL TERMINATION OF THE PROGRAM. TO SAVE
SPACE PLEASE DELETE THESE FILES MANUALLY!)
file stats.out exists - renaming.
MFD flow direction
D8CUT=999999986991104.000000
Memory size: 1000.00M (1048576000) bytes
Memory manager registering memory in MM_IGNORE_MEMORY_EXCEEDED mode.
total elements=388934784, nodata elements=303543501
largest temporary files:
FLOW: 6.36G (6831302640) [85391283 elements, 80B each]
Will need at least 40.57G (43560695808) space available in /home/cgn/tmp/
COMPUTING FLOW DIRECTIONS
classifying nodata (inner & boundary)
file=/home/cgn/tmp//STREAM_5Xwb5K:cannot read!: Bad address
r.terraflow:
Aborted (core dumped)
[Raster MASK present]
r.terraflow:
Known bug (#775); see:
http://trac.osgeo.org/grass/ticket/775
