[GRASS-dev] liblas, laslib, lastools, anaconda, and GRASS
So here is an email chain with the conda-forge maintainers of the LAStools package about liblas in Anaconda which is not liblas, but actually laslib misnamed. This is why there is no liblas-config. Since liblas.dylib is installed with the lastools package in Anaconda, I asked if they might also create a liblas-config file (not currently installed) so that GRASS can compile against it for LiDAR support
The upshot is that LAStools (and laslib, misnamed as liblas) can be installed through Anaconda, but not the packages we know as libLAS. Also, it seems like libLAS is no longer maintained and superseded by LASlib and related tools. I have an email from William Kyngesburye (copied) from several years ago suggesting that GRASS lidar support could potentially use LASlib instead of liblas. But I don’t know what that would involve.
MIchael
C. Michael Barton
Head, Graduate Faculty in Complex Adaptive Systems Science
Arizona State University
voice: 480-965-6262 (SHESC), 480-965-8130/727-9746 (CSDC)
fax: 480-965-7671 (SHESC), 480-727-0709 (CSDC)
www: http://www.public.asu.edu/~cmbarton, http://csdc.asu.edu
Subject: Re: [conda-forge/lastools-feedstock] can liblas-config be included in package (#3)
Date: February 21, 2018 at 5:19:45 PM MST
To: conda-forge/lastools-feedstock <lastools-feedstock@noreply.github.com>
Cc: Michael Barton <c.michael.barton@gmail.com>, Author <author@noreply.github.com>
Reply-To: conda-forge/lastools-feedstock <reply+0088d5afff3e421a9fe599968afaa891e0ddd2cfca2dc97292cf0000000116a5cea192a169ce11d01e0b@reply.github.com>
Yes. Feel free to talk to the lastools maintainer about this confusing situation…
Date: February 21, 2018 at 5:08:45 PM MST
To: conda-forge/lastools-feedstock <reply+0088d5afb432f05c9506e1ef9f0d5fb3c795a0bc4ba02c0192cf0000000116a5bd8792a169ce11d01e0b@reply.github.com>
Cc: conda-forge/lastools-feedstock <lastools-feedstock@noreply.github.com>, Author <author@noreply.github.com>
OK. This is good to know. So the file that is named liblas.dylib in the conda package of lastools is in fact laslib?
Michael
Date: February 21, 2018 at 4:06:47 PM MST
Reply-To: conda-forge/lastools-feedstock <reply+0088d5afb432f05c9506e1ef9f0d5fb3c795a0bc4ba02c0192cf0000000116a5bd8792a169ce11d01e0b@reply.github.com>
Yes the library file is called the same, but the contents are different. In an early version of this recipe i renamed the files to be clear, but that broke other software…
Date: February 21, 2018 at 2:43:46 PM MST
To: conda-forge/lastools-feedstock <reply+0088d5af64024b45f60988c0b8f9368cac4eee6363df9a7492cf0000000116a57eb892a169ce11d01e0b@reply.github.com>
Indeed. But the anaconda package installs liblas, not laslib.
Michael
Date: February 21, 2018 at 11:38:55 AM MST
Reply-To: conda-forge/lastools-feedstock <reply+0088d5af64024b45f60988c0b8f9368cac4eee6363df9a7492cf0000000116a57eb892a169ce11d01e0b@reply.github.com>
LASlib isn’t a drop in replacement for libLAS (different function names for one thing) you’d have to modify the GRASS code if you wanted to use LASlib.
Date: February 21, 2018 at 8:59:25 AM MST
To: conda-forge/lastools-feedstock <reply+0088d5afde4903f9a76a7de6418c35ec29798e65e254574992cf0000000116a4e15492a169ce11d01e0b@reply.github.com>
Cc: Vaclav Petras <wenzeslaus@gmail.com>, Eric Hutton <hutton.eric@gmail.com>
Thanks for the quick response Dan,
I have indeed seen both the open source libLAS code and the LAStools site. The thing is that the Anaconda package installs liblas.dylib into …/lib as well as command line tools in …/bin with the same names as the tools built with the libLAS code. A couple years ago, a colleague on the GRASS project looked into the (then new) LAStools distribution and thought that it could be a drop in replacement for libLAS code. So I was hoping to try this with the Anaconda build. But we need a liblas-config to do it. I’m copying a couple colleagues on GRASS who also might be able to help with this.
Michael
Date: February 21, 2018 at 12:27:16 AM MST
Reply-To: conda-forge/lastools-feedstock <reply+0088d5afde4903f9a76a7de6418c35ec29798e65e254574992cf0000000116a4e15492a169ce11d01e0b@reply.github.com>
This is the feedstock for LAStools and LASlib not libLAS which I believe is the library GRASS can be compiled against. The libLAS website has a page explaining the relationship between the two: https://www.liblas.org/lastools.html. The two libraries provide similar functionality but aren’t compatible.
From the libLAS website “As of 2014, libLAS has been almost entirely superceded by Martin Isenburg‘s LASlib library.”
More specifically this feedstock builds a fork of LAStools (https://github.com/gillins/LAStools/) which adds CMake build scrips. The standard LAStools doesn’t provide a liblas-config file, we could add one to the fork this is being build against but I think this would only make things between the two libraries more confusing.
I’m going to mark this as closed but if I am incorrect and it is LASlib you need please reopen for further discussion.
On Wed, Feb 21, 2018 at 7:43 PM, Michael Barton <Michael.Barton@asu.edu>
Since that's the case, it doesn't seem that just liblas-config would solve
it. Daniel Clewley says "LASlib isn't a drop in replacement for libLAS
(different function names for one thing) you'd have to modify the GRASS
code if you wanted to use LASlib." Perhaps simpler than changing it to
PDAL, but I'm not sure if worth it. But I haven't seen the LASlib API.
related tools.
So far various people kept libLAS alive:
https://github.com/libLAS/libLAS/commits/master
But the situation is not ideal.
liblas. But I don't know what that would involve.
As I said above, I dpn't know the LASlib API, but my guess is that it would
be possible, but I think the question is if somebody can work on it.
From what I understood replacement for libLAS is PDAL, but definitively not
a drop-in one. I was not able to dedicate any time to it lately except for
accepting patch from felixg few days ago which makes v.in.pdal work with
current PDAL. Also I have been told that PDAL package for Anaconda is
coming soon (in days).
Best,
Vaclav
MIchael
*Subject: **Re: [conda-forge/lastools-feedstock] can liblas-config be
included in package (#3)*
*Date: *February 21, 2018 at 11:38:55 AM MST
*To: *conda-forge/lastools-feedstock <lastools-feedstock@noreply.gi
thub.com>
*Cc: *Michael Barton <c.michael.barton@gmail.com>, Author <
*Reply-To: *conda-forge/lastools-feedstock <reply+0088d5af64024b45f60988c
b@reply.github.com>
LASlib isn't a drop in replacement for libLAS (different function names
for one thing) you'd have to modify the GRASS code if you wanted to use
LASlib.
*Date: *February 21, 2018 at 8:59:25 AM MST
*To: *conda-forge/lastools-feedstock <reply+0088d5afde4903f9a76a7de
b@reply.github.com>
*Cc: *Vaclav Petras <wenzeslaus@gmail.com>, Eric Hutton <
The thing is that the Anaconda package installs liblas.dylib into ../lib as
well as command line tools in ../bin with the same names as the tools built
the Anaconda build. But we need a liblas-config to do it. I'm copying a
Michael
*Date: *February 21, 2018 at 12:27:16 AM MST
thub.com>
*Reply-To: *conda-forge/lastools-feedstock <reply+0088d5afde4903f9a76a7de
b@reply.github.com>
This is the feedstock for LAStools <https://github.com/LAStools/LAStools&gt; and
LASlib not libLAS <https://github.com/libLAS/libLAS&gt; which I believe is
stools.html. The two libraries provide similar functionality but aren't
compatible.
From the libLAS website "As of 2014, libLAS has been almost entirely
superceded by Martin Isenburg‘s LASlib library."
standard LAStools doesn't provide a liblas-config file, we could add one
I'm going to mark this as closed but if I am incorrect and it is LASlib
Yes pdal is a good possibility. But we neither yet have pdal replacements for the lidar tools nor pdal in anaconda. I don’t know which is the better near term solution for lidar and which would be easier to to implement.
Michael
On Wed, Feb 21, 2018 at 7:43 PM, Michael Barton <Michael.Barton@asu.edu> wrote:
Since that’s the case, it doesn’t seem that just liblas-config would solve it. Daniel Clewley says “LASlib isn’t a drop in replacement for libLAS (different function names for one thing) you’d have to modify the GRASS code if you wanted to use LASlib.” Perhaps simpler than changing it to PDAL, but I’m not sure if worth it. But I haven’t seen the LASlib API.
As I said above, I dpn’t know the LASlib API, but my guess is that it would be possible, but I think the question is if somebody can work on it.
From what I understood replacement for libLAS is PDAL, but definitively not a drop-in one. I was not able to dedicate any time to it lately except for accepting patch from felixg few days ago which makes v.in.pdal work with current PDAL. Also I have been told that PDAL package for Anaconda is coming soon (in days).
Best,
Vaclav
MIchael
Michael
A couple of notes:
  • Brad Chambers from the PDAL project has put forward an initial Anaconda build recipe that is waiting to be merged.
  • I have updated the libLAS website to tell people to use PDAL if they’re starting fresh
  • Sorry about the naming thing.
I hope enough developer attention can get GRASS caught up to PDAL for on-the-way-in data ingest and processing. PDAL brings a lot of filtering and processing possibilities that just aren’t available in libLAS. Most notably, it supports the latest ASPRS LAS 1.4 (and LAZ) specification, which libLAS does not, in addition to about 15 other formats. PDAL is also actively developed, patched, and improved. libLAS has not been in 5+ years except for critical outside patches.
Use PDAL :slight_smile:
Howard
Best,
Vaclav
MIchael
Michael
This is good news. I hope that GRASS can take advantage of this work.
Michael
Best,
Vaclav
MIchael
Michael
If anyone attending the Bonn Code Sprint [1] is interested, the entire
PDAL team will be available to help someone doing such integration work.
Howard
[1] https://wiki.osgeo.org/wiki/OSGeo_Code_Sprint_2018
Michael
______________________________
C. Michael Barton
Tempe, AZ 85287-2402
USA
fax: 480-965-7671(SHESC), 480-727-0709 (CSDC)
www: http://csdc.asu.edu, http://shesc.asu.edu
On Feb 22, 2018, at 8:07 AM, Howard Butler <howard@hobu.co<mailto:howard@hobu.co>> wrote:
A couple of notes:
* Brad Chambers from the PDAL project has put forward an initial Anaconda build recipe that is waiting to be merged.
* I have updated the libLAS website to tell people to use PDAL if they're starting fresh
* Sorry about the naming thing.
I hope enough developer attention can get GRASS caught up to PDAL for on-the-way-in data ingest and processing. PDAL brings a lot of filtering and processing possibilities that just aren't available in libLAS. Most notably, it supports the latest ASPRS LAS 1.4 (and LAZ) specification, which libLAS does not, in addition to about 15 other formats. PDAL is also actively developed, patched, and improved. libLAS has not been in 5+ years except for critical outside patches.
Howard
On Feb 21, 2018, at 9:29 PM, Michael Barton <Michael.Barton@asu.edu<mailto:Michael.Barton@asu.edu>> wrote:
Yes pdal is a good possibility. But we neither yet have pdal replacements for the lidar tools nor pdal in anaconda. I don't know which is the better near term solution for lidar and which would be easier to to implement.
Michael
C. Michael Barton
www: http://www.public.asu.edu/~cmbarton, http://csdc.asu.edu/&gt;
On Feb 21, 2018, at 7:43 PM, Vaclav Petras <wenzeslaus@gmail.com<mailto:wenzeslaus@gmail.com>> wrote:
On Wed, Feb 21, 2018 at 7:43 PM, Michael Barton <Michael.Barton@asu.edu<mailto:Michael.Barton@asu.edu>> wrote:
Since that's the case, it doesn't seem that just liblas-config would solve it. Daniel Clewley says "LASlib isn't a drop in replacement for libLAS (different function names for one thing) you'd have to modify the GRASS code if you wanted to use LASlib." Perhaps simpler than changing it to PDAL, but I'm not sure if worth it. But I haven't seen the LASlib API.
https://github.com/libLAS/libLAS/commits/master&lt;https://urldefense.proofpoint.com/v2/url?u=https-3A__github.com_libLAS_libLAS_commits_master&d=DwMFaQ&c=l45AxH-kUV29SRQusp9vYR0n1GycN4_2jInuKy6zbqQ&r=lk-7X7CEOMDN8GaGVhiDsuO6gEp1wbG6nfT1XEEEtR0&m=_O4k1Vw2r12rLzx299WafFcaDaH01hzHGCoCuf94J0I&s=Kt7DFBhZJWvgpo4vM-1sXm32KiKyQ5eGF-t9k3yBUzo&e=&gt;
I have an email from William Kyngesburye (copied) from several years ago suggesting that GRASS lidar support could potentially use LASlib instead of liblas. But I don't know what that would involve.
As I said above, I dpn't know the LASlib API, but my guess is that it would be possible, but I think the question is if somebody can work on it.
Best,
Vaclav
MIchael
From: Daniel Clewley <notifications@github.com<mailto:notifications@github.com>>
To: conda-forge/lastools-feedstock <lastools-feedstock@noreply.github.com<mailto:lastools-feedstock@noreply.github.com>>
Cc: Michael Barton <c.michael.barton@gmail.com<mailto:c.michael.barton@gmail.com>>, Author <author@noreply.github.com<mailto:author@noreply.github.com>>
Reply-To: conda-forge/lastools-feedstock <reply+0088d5af64024b45f60988c0b8f9368cac4eee6363df9a7492cf0000000116a57eb892a169ce11d01e0b@reply.github.com<mailto:reply+0088d5af64024b45f60988c0b8f9368cac4eee6363df9a7492cf0000000116a57eb892a169ce11d01e0b@reply.github.com>>
From: Michael Barton <c.michael.barton@gmail.com<mailto:c.michael.barton@gmail.com>>
To: conda-forge/lastools-feedstock <reply+0088d5afde4903f9a76a7de6418c35ec29798e65e254574992cf0000000116a4e15492a169ce11d01e0b@reply.github.com<mailto:reply+0088d5afde4903f9a76a7de6418c35ec29798e65e254574992cf0000000116a4e15492a169ce11d01e0b@reply.github.com>>
Cc: Vaclav Petras <wenzeslaus@gmail.com<mailto:wenzeslaus@gmail.com>>, Eric Hutton <hutton.eric@gmail.com<mailto:hutton.eric@gmail.com>>
I have indeed seen both the open source libLAS code and the LAStools site. The thing is that the Anaconda package installs liblas.dylib into ../lib as well as command line tools in ../bin with the same names as the tools built with the libLAS code. A couple years ago, a colleague on the GRASS project looked into the (then new) LAStools distribution and thought that it could be a drop in replacement for libLAS code. So I was hoping to try this with the Anaconda build. But we need a liblas-config to do it. I'm copying a couple colleagues on GRASS who also might be able to help with this.
Michael
Reply-To: conda-forge/lastools-feedstock <reply+0088d5afde4903f9a76a7de6418c35ec29798e65e254574992cf0000000116a4e15492a169ce11d01e0b@reply.github.com<mailto:reply+0088d5afde4903f9a76a7de6418c35ec29798e65e254574992cf0000000116a4e15492a169ce11d01e0b@reply.github.com>>
This is the feedstock for LAStools<https://urldefense.proofpoint.com/v2/url?u=https-3A__github.com_LAStools_LAStools&d=DwMFaQ&c=l45AxH-kUV29SRQusp9vYR0n1GycN4_2jInuKy6zbqQ&r=lk-7X7CEOMDN8GaGVhiDsuO6gEp1wbG6nfT1XEEEtR0&m=_O4k1Vw2r12rLzx299WafFcaDaH01hzHGCoCuf94J0I&s=ldj8Sw8X5ftlAivmAsG7tmePCgMcO2HxM6XH99LrTfU&e=&gt; and LASlib not libLAS<https://urldefense.proofpoint.com/v2/url?u=https-3A__github.com_libLAS_libLAS&d=DwMFaQ&c=l45AxH-kUV29SRQusp9vYR0n1GycN4_2jInuKy6zbqQ&r=lk-7X7CEOMDN8GaGVhiDsuO6gEp1wbG6nfT1XEEEtR0&m=_O4k1Vw2r12rLzx299WafFcaDaH01hzHGCoCuf94J0I&s=GuVlnoktk-csitrgckBePx4WJ1v_ZYXiIl8B51Ydttk&e=&gt; which I believe is the library GRASS can be compiled against. The libLAS website has a page explaining the relationship between the two: https://www.liblas.org/lastools.html&lt;https://urldefense.proofpoint.com/v2/url?u=https-3A__www.liblas.org_lastools.html&d=DwMFaQ&c=l45AxH-kUV29SRQusp9vYR0n1GycN4_2jInuKy6zbqQ&r=lk-7X7CEOMDN8GaGVhiDsuO6gEp1wbG6nfT1XEEEtR0&m=_O4k1Vw2r12rLzx299WafFcaDaH01hzHGCoCuf94J0I&s=TJQ1eSBXpa8L3IrseTebZgyoHHFaNnOxyqkHZbdxQ88&e=&gt;\. The two libraries provide similar functionality but aren't compatible.
From the libLAS website "As of 2014, libLAS has been almost entirely superceded by Martin Isenburg‘s LASlib library."
More specifically this feedstock builds a fork of LAStools (https://github.com/gillins/LAStools/&lt;https://urldefense.proofpoint.com/v2/url?u=https-3A__github.com_gillins_LAStools_&d=DwMFaQ&c=l45AxH-kUV29SRQusp9vYR0n1GycN4_2jInuKy6zbqQ&r=lk-7X7CEOMDN8GaGVhiDsuO6gEp1wbG6nfT1XEEEtR0&m=_O4k1Vw2r12rLzx299WafFcaDaH01hzHGCoCuf94J0I&s=wQwQ2hTaHMK_RPNZcXN3rVYXsqw6UAnnYFN0kv4AuD4&e=&gt;\) which adds CMake build scrips. The standard LAStools doesn't provide a liblas-config file, we could add one to the fork this is being build against but I think this would only make things between the two libraries more confusing.
I'm going to mark this as closed but if I am incorrect and it is LASlib you need please reopen for further discussion.
grass-dev mailing list
grass-dev@lists.osgeo.org<mailto:grass-dev@lists.osgeo.org>
https://lists.osgeo.org/mailman/listinfo/grass-dev
Howard
Yes, there will be at least eight GRASS devs:
https://grasswiki.osgeo.org/wiki/GRASS_GIS_Community_Sprint_Bonn_2018#Planned_participation
Glad to speak in person to the PDAL team!
