[GRASS-dev] libLAS on Ubuntu 14.04
I was trying to compile GRASS with libLAS but ./configure says no.
I used:
–with-liblas-config=/usr/bin/liblas-config
and I have all liblas packages from standard Ubuntu 14.04 repository (libLAS version is 1.7.0 which is the current stable release).
Since configure went OK but the result for libLAS was “no”, I tried to compile and run the ./configure’s testing code myself.
Code:
#include <liblas/capi/liblas.h>
int main() {
LASReader_Create(“foo”);
; return 0; }
Compilation:
gcc liblastest.c -o liblastest -ggdb -L/usr/lib -llas -llas_c -L/usr/lib/x86_64-linux-gnu /usr/lib/x86_64-linux-gnu/libboost_program_options.so.1.54.0 /usr/lib/x86_64-linux-gnu/libboost_thread.so.1.54.0 /usr/lib/libgdal.so /usr/lib/libgeotiff.so /usr/lib/x86_64-linux-gnu/libtiff.so $(liblas-config --includes)
Debugging test:
gdb liblastest
Starting program: /home/vasek/dev/grass/test/liblastest
[Thread debugging using libthread_db enabled]
Using host libthread_db library “/lib/x86_64-linux-gnu/libthread_db.so.1”.
Program received signal SIGSEGV, Segmentation fault.
0x00007ffff7285471 in std::istream::seekg(std::fpos<__mbstate_t>) () from /usr/lib/x86_64-linux-gnu/libstdc++.so.6
(gdb) bt
#0 0x00007ffff7285471 in std::istream::seekg(std::fpos<__mbstate_t>) () from /usr/lib/x86_64-linux-gnu/libstdc++.so.6
#1 0x00007ffff759597b in liblas::detail::reader::Header::ReadHeader() () from /usr/lib/liblas.so.2
#2 0x00007ffff754713b in liblas::ReaderFactory::CreateWithStream(std::istream&) () from /usr/lib/liblas.so.2
#3 0x00007ffff7bb1a80 in LASReader_Create () from /usr/lib/liblas_c.so.2
#4 0x00000000004006ab in main () at liblastest.c:4
So the test failed with segmentation fault but it would actually fail during compilation if I would use liblas-config --libs because the boost libraries are libboost_program_options.so.1.54.0 on my computer while liblas-config --libs says just libboost_program_options.so (same for thread library).
It seems that the thing with boost libraries is a packaging issue but I’m not sure about the other ones. I can repeat it outside GRASS I don’t know if this is actually what GRASS is doing and if it makes sense.
Was somebody successful with libLAS on Ubuntu 14.04 and what is the general procedure for Linux anyway?
Vaclav
I can confirm the issue,
also by trying these configure options it is not helping:
--with-liblas --with-liblas-config
--with-liblas --with-liblas-config=/usr/bin/liblas-config
--with-liblas=yes --with-liblas-config
--with-liblas=yes --with-liblas-config=/usr/bin/liblas-config
Also two targets are found, both valid (v1.7.0) and identical:
whereis liblas-config
liblas-config: /usr/bin/liblas-config /usr/bin/X11/liblas-config
/usr/share/man/man1/liblas-config.1.gz
$ ls -aslh /usr/bin/X11/liblas-config
4.0K -rwxr-xr-x 1 root root 2.5K Feb 26 14:43 /usr/bin/X11/liblas-config
$ ls -aslh /usr/bin/liblas-config
4.0K -rwxr-xr-x 1 root root 2.5K Feb 26 14:43 /usr/bin/liblas-config
On 23/05/2014, Vaclav Petras <wenzeslaus@gmail.com> wrote:
I used:
Since configure went OK but the result for libLAS was "no", I tried to
compile and run the ./configure's testing code myself.
Code:
int main() {
LASReader_Create("foo");
; return 0; }
Compilation:
--includes)
Debugging test:
gdb liblastest
Using host libthread_db library "/lib/x86_64-linux-gnu/libthread_db.so.1".
(gdb) bt
during compilation if I would use `liblas-config --libs` because the boost
libraries are `libboost_program_options.so.1.54.0` on my computer while
`liblas-config --libs` says just `libboost_program_options.so` (same for
thread library).
It seems that the thing with boost libraries is a packaging issue but I'm
not sure about the other ones. I can repeat it outside GRASS I don't know
Vaclav
Possibly due to linking with gcc rather than g++. But that doesn't
matter, as configure tests don't normally try to execute the program
(that doesn't work if you're cross-compiling); they only care whether
linking succeeds.
thread library).
You may need to install a -devel package, e.g. boost-devel or
whatever.
Typically, the unversioned symlink is in the -devel package, as it's
only needed for compiling programs which use the library; running them
will use either the library itself or a symlink which includes at
least the major version number.
On Fri, May 23, 2014 at 2:53 PM, Glynn Clements <glynn@gclements.plus.com>wrote:
linking succeeds.
I have to remember this gcc vs g++ possible issue and that ./cofigure does
not execute. However, it did not helped me now. My sample program still
segfaults when compiled with g++.
boost
> thread library).
whatever.
I installed libboost-thread-dev and libboost-program-options-dev and
compilation works with $(liblas-config --libs) $(liblas-config --includes).
So, it should work in ./configure but the result is still "libLAS support:
no".
Hi Vaclav,
If it helps: http://trac.osgeo.org/grass/ticket/2065
On Fri, May 23, 2014 at 9:25 PM, Vaclav Petras <wenzeslaus@gmail.com> wrote:
grass-dev mailing list
grass-dev@lists.osgeo.org
Rashad
On Fri, May 23, 2014 at 2:53 PM, Glynn Clements <glynn@gclements.plus.com> wrote:
Possibly due to linking with gcc rather than g++. But that doesn’t
matter, as configure tests don’t normally try to execute the program
(that doesn’t work if you’re cross-compiling); they only care whether
linking succeeds.
I have to remember this gcc vs g++ possible issue and that ./cofigure does not execute. However, it did not helped me now. My sample program still segfaults when compiled with g++.
thread library).
whatever.
Typically, the unversioned symlink is in the -devel package, as it’s
I installed libboost-thread-dev and libboost-program-options-dev and compilation works with $(liblas-config --libs) $(liblas-config --includes). So, it should work in ./configure but the result is still “libLAS support: no”.
On Fri, May 23, 2014 at 3:35 PM, Rashad M <mohammedrashadkm@gmail.com>wrote:
Hi Vaclav,
Thanks, I tried to unify the variables (r57541 and the patch from #2065):
CFLAGS="$CFLAGS $LIBLAS_CFLAGS $LIBLAS_INC"
CPPFLAGS="$CPPFLAGS $LIBLAS_CPPFLAGS $LIBLAS_INC"
but it did not help. I see that the ticket is closed and it puzzles me that
it is not enough for me.
linking succeeds.
I've tried also cxxflags and a file with cpp extension:
g++ liblastest.cpp -o liblastest -ggdb $(liblas-config --libs)
$(liblas-config --includes) $(liblas-config --cxxflags)
but it still segfaults (with and without -ggdb). Should I report this
somewhere (Launchpad, libLAS)?
boost
for
> thread library).
whatever.
no".
   Rashad
Hi Vaclav,
try linking to las_c instead of las
gcc liblastest.c -o liblastest -ggdb -L/usr/lib -llas_c /usr/lib/libgdal.so /usr/lib/libgeotiff.so /usr/lib/x86_64-linux-gnu/libtiff.so
boost and las.so not required here, i think
On Fri, May 23, 2014 at 10:04 PM, Vaclav Petras <wenzeslaus@gmail.com> wrote:
Rashad
On Fri, May 23, 2014 at 3:35 PM, Rashad M <mohammedrashadkm@gmail.com> wrote:
Hi Vaclav,
CFLAGS=“$CFLAGS $LIBLAS_CFLAGS $LIBLAS_INC”
CPPFLAGS=“$CPPFLAGS $LIBLAS_CPPFLAGS $LIBLAS_INC”
but it did not help. I see that the ticket is closed and it puzzles me that it is not enough for me.
I’ve tried also cxxflags and a file with cpp extension:
g++ liblastest.cpp -o liblastest -ggdb $(liblas-config --libs) $(liblas-config --includes) $(liblas-config --cxxflags)
but it still segfaults (with and without -ggdb). Should I report this somewhere (Launchpad, libLAS)?
linking succeeds.
Rashad
thread library).
whatever.
On Fri, May 23, 2014 at 4:52 PM, Rashad M <mohammedrashadkm@gmail.com>wrote:
Hi Vaclav,
Thanks but no success here.
Hi Vaclav,
linking succeeds.
boost
while
for
> thread library).
whatever.
no".
   Rashad
   Rashad
Much interesting why it ask for c++ when using C headers ?
On Fri, May 23, 2014 at 10:58 PM, Vaclav Petras <wenzeslaus@gmail.com> wrote:
Rashad
On Fri, May 23, 2014 at 4:52 PM, Rashad M <mohammedrashadkm@gmail.com> wrote:
Hi Vaclav,
Rashad
Hi Vaclav,
linking succeeds.
Rashad
thread library).
whatever.
Hi again!.
Do you have ctest passed?
For me i have:
Test command: /home/rashad/Desktop/libLAS-1.7.0/build/bin/Release/liblas_test “/home/rashad/Desktop/libLAS-1.7.0/test/data”
1: Test timeout computed to be: 1500
1: libLAS Test Suite:
1: ==================
1: liblas::Bounds: …
1: liblas::Error: …
1: liblas::Header: …
1: liblas::Point: …
1: liblas::Reader: …
1: liblas::SpatialReference: .
1: liblas::VariableRecord: …
1: liblas::Writer: …
1: liblas::guid: …
1: liblas::lasreader_iterator: …
1:
1: tests summary: ok:88
1/1 Test #1: liblas_test … Passed 0.02 sec
100% tests passed, 0 tests failed out of 1
If so you need update the test in grass configure. BTW. it seems like c library is not used anymore.You must check this with libLAS devs. But for now try updating configure test code
On Fri, May 23, 2014 at 11:03 PM, Rashad M <mohammedrashadkm@gmail.com> wrote:
Rashad
Rashad
Hi Vaclav,
Rashad
Hi Vaclav,
linking succeeds.
Rashad
thread library).
whatever.
I had the same problem with the latest grass 71 svn version (from
today) under ubuntu 14.04 and I certainly solved it installing
libboost-all-dev and the config option: --with-liblas=yes
Thank you and cheers,
Javier
On Fri, May 23, 2014 at 11:13 PM, Rashad M <mohammedrashadkm@gmail.com> wrote:
Hi again!.
For me i have:
Test command:
"/home/rashad/Desktop/libLAS-1.7.0/test/data"
1: liblas::Bounds: ....
1: liblas::Error: ...
1: liblas::Header: ............
1: liblas::Point: ...................
1: liblas::Reader: ........
1: liblas::VariableRecord: ......
1: liblas::Writer: ......
1: liblas::guid: .......
1: liblas::lasreader_iterator: ......................
1:
1/1 Test #1: liblas_test ...................... Passed 0.02 sec
wrote:
Hi Vaclav,
wrote:
Hi Vaclav,
#2065):
whether
linking succeeds.
> the boost
> while
> (same for
> thread library).
whatever.
them
no".
   Rashad
   Rashad
   Rashad
   Rashad
On Thu, May 29, 2014 at 1:09 PM, Javier Martínez-López <
javi.martinez.lopez@gmail.com> wrote:
Thank you. This was very helpful. The problem was that I included only
in my ./configure call. I thought that this is enough. When I added
--with-liblas=yes
it started to work. After ./configure ... && make, I have r.in.lidar and
v.in.lidar.
I still have just libboost-thread-dev and libboost-program-options-dev, the
libboost-all-dev package is not necessary, although it is the simplest
option.
I don't understand the think with --with-liblas=yes, I really though I read
here that it is not necessary (once you have --with-liblas-config) and Yann
was saying that different combinations of --with-liblas* does not work for
him.
There is still the problem with different content of CFLAGS and CPPFLAGS
variables (r57541 and the patch from #2065) in ./configure and also I'm not
able to run the test program from ./configure myself. I don't know how this
is important.
Thanks all for help. I'll try this also on other computers with Ubuntu
14.04 and I'll let you know if it will not work.
Vaclav
I used:
I have libboost-thread-dev, libboost-program-options-dev, and
libboost-all-dev installed
in configure options: --with-liblas-config=/usr/bin/liblas-config
--with-liblas=yes
still:
checking whether to use libLAS... yes
checking for liblas-config... /usr/bin/liblas-config
configure: error: *** Unable to locate libLAS library.
Full config script:
CFLAGS="-g -Wall"
./configure --with-cxx --with-wxwidgets --with-freetype=yes
--with-postgres=no --with-sqlite=yes --without-tcltk
--enable-largefile=yes --with-freetype-includes=/usr/include/freetype2
--with-opengl-libs=/usr/include/GL --with-readline --with-python=yes
--with-lapack --with-gdal=/usr/bin/gdal-config
--with-proj-share=/usr/share/proj --with-pthread
--with-liblas-config=/usr/bin/liblas-config --with-liblas=yes
--with-blas
--with-liblas=yes
v.in.lidar.
option.
him.
is important.
Vaclav
I used:
More from config.log (thx MarkusM)
configure:6198: checking whether to use libLAS
configure:6215: checking for liblas-config
configure:6272: gcc -o conftest -g -O2 -g -O2 -fstack-protector
--param=ssp-buffer-size=4 -Wformat -Werror=format-security
-D_FORTIFY_SOURCE=2 -I/usr/include -I/usr/include/gdal
-I/usr/include/geotiff -I/usr/include/x86_64-linux-gnu
-Wl,--export-dynamic conftest.c -L/usr/lib -llas -llas_c
/usr/lib/x86_64-linux-gnu/libboost_thread.so /usr/lib/libgdal.so
/usr/lib/libgeotiff.so /usr/lib/x86_64-linux-gnu/libtiff.so 1>&5
configure:6266:32: fatal error: liblas/capi/liblas.h: No such file or directory
compilation terminated.
configure: failed program was:
#line 6265 "configure"
#include "confdefs.h"
int main() {
; return 0; }
configure:6287: gcc -o conftest -g -O2 -g -O2 -fstack-protector
configure:6281:32: fatal error: liblas/capi/liblas.h: No such file or directory
#line 6280 "configure"
int main() {
; return 0; }
On 31/05/2014, Yann Chemin <ychemin@gmail.com> wrote:
--with-liblas=yes
still:
Full config script:
CFLAGS="-g -Wall"
--with-blas
--with-liblas=yes
v.in.lidar.
the
option.
read
Yann
for
him.
not
this
is important.
Vaclav
I used:
directory
Hm, are you sure you have the liblas-c-dev package? And are you sure the
file liblas/capi/liblas.h is there (on include path, in case of the
liblas-c-dev package it should be /usr/include/liblas/capi/liblas.h)?
OK it was that thanks Vaclav
Summary:
sudo apt-get install libboost-thread-dev,libboost-program-options-dev
liblas-c-dev
--with-liblas=yes
directory
Summary:
liblas-c-dev
--with-liblas=yes
I updated the wiki for 14.04 and added libLAS packages and added libLAS to
configure for GRASS 7. I think the page needs some refactoring. I have hard
time to navigate it when I understand most of the terms but the problem is
the high number of possibilities.
http://grasswiki.osgeo.org/wiki/Compile_and_Install_Ubuntu
>> directory
Looking into the Wiki page I got FFMPEG configured by this:
sudo apt-get install libffms2-dev
and from wiki page:
--with-ffmpeg=yes \
--with-ffmpeg-includes="/usr/include/libavcodec
/usr/include/libavformat /usr/include/libswscale
/usr/include/libavutil"
Summary:
liblas-c-dev
--with-liblas=yes
to
>> directory
> the
