details on r40831:
Performance has been increased for all modules by reducing the default segment size, interpolation settings are not affected. Previously, the modules seemed to be optimized for settings where only one segment was needed. As soon as several segments where needed, processing time increased drastically. Fixed for all modules, now optimized for larger datasets.
Sometimes interpolation settings were modified for the last row and column segments, i.e. for these segments different interpolation settings were used than for the other segments. The same spline step values are now used for all segments.
All modules have a new flag to estimate point density and mean distance between points. This mean distance is the minimum spline step, according to the documentation recommended spline steps are 2 to 4 times the mean distance, depending on the module.
All modules now create a proper name for the auxiliar table, sometimes a name was created but a different one was used or a fully qualified name with @ was used: illegal table name.
Several modules had memory leaks when accessing the auxiliar table, all are fixed.
v.lidar.edgedetection assigned category 0 instead of 3 to unknown points (neither edge nor terrain), fixed. There was a bad memory leak in v.lidar.edgedetection, fixed.
v.outlier could not properly detect outliers if several segments were needed, the points falling into the overlapping zones were not properly updated (uninitialized variable used).
v.surf.bspline no longer produces artifacts along region boundaries and is now optimized for larger datasets. AFAICT it did not properly work if the region had to be subdivided into several segments, it was restricted to one segment.
test environment was nc_spm_08
g.region vect=elev_lid792_bepts@PERMANENT res=1
north: 221230
south: 219580
west: 637740
east: 639530
nsres: 1
ewres: 1
rows: 1650
cols: 1790
cells: 2953500
e.g. for grass64
v.outlier --o --v input=elev_lid792_bepts@PERMANENT output=elev_lid792_bepts_nooutliers64 outlier=elev_lid792_bepts_outliers64 soe=5 son=5 thres_o=0.1
and grass7
v.outlier --o --v input=elev_lid792_bepts@PERMANENT output=elev_lid792_bepts_nooutliers outlier=elev_lid792_bepts_outliers soe=5 son=5 thres_o=0.1
these settings will detect more outliers than are probably there, they are for illustration of the artefacts.
obvious artefacts in elev_lid792_bepts_outliers64
or in grass64
v.surf.bspline --o --v input=elev_lid792_bepts@PERMANENT raster=elev_lid792_rast64 sie=5 sin=5 type=bicubic lambda_i=0.1
vs. grass7
v.surf.bspline --o --v input=elev_lid792_bepts@PERMANENT raster=elev_lid792_rast sie=5 sin=5 type=bicubic lambda_i=0.1
no more artefacts along the region boundaries and faster
