[GRASS-dev] Linearly stretch an image to match another image's Mean and StdDev
Hi Devs & Advanced Users.
Part of an image processing algorithm is "linearly stretching an image to
match another image's Mean and StdDev".
How can we replicate this in GRASS? Already implemented as part of an existing
GRASS module? Is i.histo.match actually doing this?
Thank you, Nikos
On Sun, Nov 3, 2013 at 3:15 PM, Nikos Alexandris
Yes, this is offered by i.histo.match:
http://svn.osgeo.org/grass/grass-addons/grass7/imagery/i.histo.match/i.histo.match.html
I agree that the manual page could be a bit more exhaustive :slight_smile:
Nikos A:
> existing GRASS module? Is i.histo.match actually doing this?
Markus N:
.match.html
Is it really exactly that? I remember asking this (more or less) on
"22/02/2013 14:24" ("Re: [GRASS-dev] On i.histo.match (Re: On (Landsat)
imagery naming patterns)").
This is then a Real Hit! :smiley:
Thank you Markus
Hi Nikos,
it is not identical since i.histo.match uses a more advanced way. With
a simple linear scaling you can likely not gain much.
On Sunday 03 of November 2013 16:57:34 Markus Neteler wrote:
Hi Nikos,
Thank you for the clarification Markus.
Nikos
Hmmm, I need to check what is happening there.
Also nikos, take care, as I noticed i.histo.match [0] uses reclass to
produce the output map. Which makes it very sensitive in the input
data type.
N
[0] https://svn.osgeo.org/grass/grass-addons/grass7/imagery/i.histo.match/i.histo.match.py
On Sun, Nov 3, 2013 at 6:00 PM, Nikos Alexandris
Hi Nikos,
Nikos
grass-dev mailing list
grass-dev@lists.osgeo.org
data type.
[0]
to.match.py
Thanks Nik. This is already "known". See also:
<http://lists.osgeo.org/pipermail/grass-dev/2013-February/062159.html&gt; and
follow-ups.
N
On Mon, Nov 4, 2013 at 4:54 AM, Nikos Alexandris
data type.
[0]
to.match.py
follow-ups.
Please open a ticket for this.
match another image’s Mean and StdDev". How can we replicate this in GRASS?
Already implemented as part of…
“i.pansharpen”, code lines 348 - 431 maybe?
Thanks, Nikos
