[GRASS-dev] load_env() issues in startup
Currently, .grass7/bashrc is partially broken. This file is read by two functions in the startup script: load_env() and *_startup() (https://trac.osgeo.org/grass/ticket/3462). Commenting out export lines in .grass7/bashrc doesn’t work because load_env() splits each line twice (once by space and once more by equal) to create environment variables without ignoring commented lines. It doesn’t matter whether a line is alias or export, or whatever as long as it contains one space and one equal sign. Also, load_env() doesn’t expand environment variables in each line. For example, the following two lines:
alias vi=‘vim’
#export PATH=“$PATH:grass/scripts”
export GDAL_DRIVER_PATH=“$HOME/gdalplugins”
would create three environment variables:
vi=“‘vim’”
PATH=“…grass paths…:$PATH:grass/scripts”
The first variable is not meant to be created at all, PATH shouldn’t be modified because it’s commented out, and GDAL_DRIVER_PATH is not usable because $HOME is not expanded.
Now, my question is why do we need a separate function load_env() to “manually” create environment variables instead of just writing out all these lines into .bashrc in the mapset and letting bash handling everything? Is it by design or a bug?
Huidae
Huidae Cho, Ph.D., GISP, PE (MD), CFM, M.ASCE
Open Source GIS Developer, GRASS GIS Development Team
OK… Tried to work around this limitation by adding spaces and $HOME is now expanded into the location directory. Hmm… I kind of see why we’re doing this. Maybe, better to fix load_env()?
Huidae
