Hi, this is maybe similar to ticket #3693 [0].
@neteler In [0], the first example to create a Location, is performed as
root. Curious, why so? Why not as a simple user?
I just try to update my grassyan Dockerfile [0] and it fails at the
point of creating a Location, for the sake of testing. I don't know if
this is relevant with what is reported in ticket #3693:
[0] https://trac.osgeo.org/grass/ticket/3693
[1] https://gitlab.com/NikosAlexandris/grassyan
Step 47/52 : RUN grass -text -e -c EPSG:4326 "$GRASSDB/$TEMPORARY_MAPSET" RUN grass -text "$GRASSDB/$TEMPORARY_MAPSET/PERMANENT" --exec g.region -p
---> Running in 4dab4125dec7
Starting GRASS GIS...
Creating new GRASS GIS location <temporary_Mapset>...
File "/usr/local/bin/grass", line 2242, in <module>
main()
File "/usr/local/bin/grass", line 2153, in main
geofile=params.geofile, create_new=True)
File "/usr/local/bin/grass", line 1046, in set_mapset
create_location(gisdbase, location_name, geofile)
File "/usr/local/bin/grass", line 837, in create_location
from grass.script import core as gcore # pylint: disable=E0611
ImportError: No module named grass.script
The command '/bin/sh -c grass -text -e -c EPSG:4326 "$GRASSDB/$TEMPORARY_MAPSET" RUN grass -text "$GRASSDB/$TEMPORARY_MAPSET/PERMANENT" --exec g.region -p' returned a non-zero code: 1
Don't mind the misleading `temporary_Mapset` name, it should be
`temporary_Location` instead. Even interactively, creating a Location
will fail too:
grassyan@2ced1e57a44e:~$ grass --version
GRASS GIS 7.7.svn
main()
File "/usr/local/bin/grass", line 2040, in main
params = parse_cmdline(sys.argv[1:], default_gui=default_gui)
File "/usr/local/bin/grass", line 1940, in parse_cmdline
message('\n' + readfile(gpath("etc", "license")))
File "/usr/local/bin/grass", line 263, in readfile
f = open(path, 'r')
IOError: [Errno 2] No such file or directory: 'dist.x86_64-pc-linux-gnu/etc/license'
grassyan@2ced1e57a44e:~$ grass74 --version
GRASS GIS 7.4.2
File "/usr/bin/grass74", line 2027, in <module>
main()
File "/usr/bin/grass74", line 1839, in main
File "/usr/bin/grass74", line 1744, in parse_cmdline
File "/usr/bin/grass74", line 229, in readfile
f = open(path, 'r')
and
grass77 -c 'epsg:4326' /home/grassyan/grassdb/test
WARNING: GRASS GUI not found. Please check your installation.
Switching to text based interface mode.
Hit RETURN to continue.
Creating new GRASS GIS location <test>...
File "/usr/local/bin/grass77", line 2242, in <module>
main()
File "/usr/local/bin/grass77", line 2153, in main
File "/usr/local/bin/grass77", line 1046, in set_mapset
File "/usr/local/bin/grass77", line 837, in create_location
Nikos
