This sounds like a good idea.
Michael
On Dec 8, 2007, at 10:00 AM, grass-dev-request@lists.osgeo.org wrote:
Send grass-dev mailing list submissions to
grass-dev@lists.osgeo.orgTo subscribe or unsubscribe via the World Wide Web, visit
or, via email, send a message with subject or body ‘help’ to
grass-dev-request@lists.osgeo.orgYou can reach the person managing the list at
grass-dev-owner@lists.osgeo.orgWhen replying, please edit your Subject line so it is more specific
than “Re: Contents of grass-dev digest…”
Today’s Topics:
- Re: location invalid if PERMANENT contains no WIND file ?
(Glynn Clements)From: Glynn Clements <glynn@gclements.plus.com>
Date: December 8, 2007 5:51:49 AM MST
To: Moritz Lennert <mlennert@club.worldonline.be>
Cc: grass-dev <grass-dev@lists.osgeo.org>
Subject: Re: [GRASS-dev] location invalid if PERMANENT contains no WIND file ?Moritz Lennert wrote:
In gis_set.tcl there is a check for a valid location which reads:
All good locations have valid PERMANENT mapset.
if {[file exists “$dir/PERMANENT/WIND”] != 0} {
set found 1Shouldn’t this check for DEFAULT_WIND instead of WIND ?
I can see some sense in that. The only time that PERMANENT/WIND will
actually be used is if PERMANENT is used as the current mapset, which
may never happen. OTOH, PERMANENT/DEFAULT_WIND must exist in order to
create new mapsets.In this particular case, I could not enter the location via the GUI
startup, but had no problem using it via the text startup.There is the same kind of test for mapsets (lines 499ff and 650ff):
if {[file exists “$database/$location/$mapset/WIND”] == 0} {
DialogGen .wrnDlg [G_msg “WARNING: invalid mapset”]
warning
[format [G_msg “Warning: <%s> is not a valid
mapset”] $mapset]
0 OK;
if { $mapset != “” && [file exists “$database/$location/$mapset/WIND”]
!= 0} {
puts stdout “GISDBASE=‘$database’;”
puts stdout “LOCATION_NAME=‘$location’;”
puts stdout “MAPSET=‘$mapset’;”
putGRASSRC $gisrc_name
exit 0
}Again, should a missing WIND file be a reason to fail entering a mapset
? I think gis_set.tcl should just silently copy PERMANENT/DEFAULT_WIND
to $mapset/WIND ?AFAIK, the idea is to prevent the user from selecting some random
subdirectory of the location as the current mapset. This allows the
location directory to have subdirectories which aren’t mapsets and
which won’t be mistaken for mapsets.The convention is that $dir is a valid location if $dir/PERMANENT/WIND
exists, and that $dir is a valid mapset if $dir/WIND exists.The former could reasonably be changed to look for
$dir/PERMANENT/DEFAULT_WIND instead of $dir/PERMANENT/WIND. I don’t
think that the latter should be changed.–
C. Michael Barton, Professor of Anthropology
Director of Graduate Studies
Arizona State University
Phone: 480-965-6262
Fax: 480-965-7671
