On Fri, Jul 21, 2006 at 09:18:56AM +0200, Maciej Sieczka wrote:
Hi
grass61 --help says:
<snip>
Parameters:
GISDBASE initial database
LOCATION_NAME initial location
MAPSET initial mapset
GISDBASE/LOCATION_NAME/MAPSET fully qualified initial LOCATION directory
</snip>
I'm wondering whether the last sentence is correct. Shouldn't it be
"fully qualified initial MAPSET directory"?
To add to confussion,
http://grass.itc.it/grass61/manuals/html61_user/grass6.html under
"Location Environment Variables" describes a LOCATION variable as "A
fully qualified path to a mapset". I think this variable name doesn't
reflect it's function and confuses the user. I know it cannot be changed
in Grass 6.x, but maybe for Grass 7 it should replaced with, eg.,
MAPSET_DIRECT or so? And LOCATION_NAME should be then replaced with
plane LOCATION, to make things more obvious.
Then, "Example 1" would look like this, which seems clear to me:
<quote>
Example 1
The environment variables are defined as follows:
MAPSET_DIRECT = /usr/local/share/grassdata/spearfish60/PERMANENT
GISDBASE = /usr/local/share/grassdata
LOCATION = spearfish60
MAPSET = PERMANENT
</quote>
Maciek
grass-dev mailing list
grass-dev@grass.itc.it
I agree with you that it's confusing, but MAPSET_DIRECT looks odd to me.
What about MAPSET_PATH? I don't want to be very picky about naming
conventions for environment variables. However, when it comes to
consistency, it looks like there is no standard.
<quote>
* Environment variables
GRASS_ADDON_PATH
GRASS_BACKGROUNDCOLOR why isn't it GRASS_BACKGROUND_COLOR?
GRASS_ERROR_MAIL
GRASS_GNUPLOT
GRASS_HEIGHT
GRASS_HTML_BROWSER
GRASS_INT_ZLIB
GRASS_MESSAGE_FORMAT
GRASS_MOUSE_BUTTON
GRASS_PAGER
GRASS_PERL
GRASS_PNGFILE GRASS_PNG_FILE?
GRASS_STDERR
GRASS_TCLSH
GRASS_TRANSPARENT
GRASS_TRUECOLOR GRASS_TRUE_COLOR?
GRASS_UI_TERM
GRASS_VERSION
GRASS_WIDTH
GRASS_WISH
* Environment variables automatically set by the startup script:
GISBASE GRASSBASE, GRASS_BASE?
GISRC GRASSRC, GRASS_RC?
* Internal environment variables
GRASS_OVERWRITE
GRASS_REGION
WIND_OVERRIDE GRASS_WIND_OVERRIDE? there is a possibility that
other softwares use the same name.
* gisenv variables
DEBUG
DM_FORM_MODE
GISDBASE do we really need GIS prefix when we're already
in grass GIS?
GIS_LOCK LOCK?
GRASS_DB_ENCODING DB_ENCODING? why do we need GRASS_ prefix for
gisenv variables?
GRASS_GUI UI since its value is not boolean but "text" or
"tcltk". GRASS_GUI="text" is somewhat strange.
LOCATION MAPSET_PATH?
LOCATION_NAME LOCATION?
MAPSET
OVERWRITE
</quote>
Just my 2 cents.
Huidae Cho
