Hello all,
related to the location wizard, perhaps what follows does not deal with
any sort of bug but my misuse of the location creation process :
If you need to create from scratch a new gisdabe, located elsewhere than
the current one, the location wizard first writes your new location
directory in the /current/ gisdbase instead of the new one you've just
set. Then when you define a new mapset or want to start from within
PERMANENT, the application fails, with this message :
Starting GRASS ...
File "/usr/local/grass-6.4.0svn/etc/wxpython/gis_set.py", line
401, in OnWizard
self.lblocations.SetSelection(self.listOfLocations.index(gWizard.location))
ValueError: list.index(x): x not in list
686, in OnStart
"set=LOCATION_NAME=%s" %
self.listOfLocations[self.lblocations.GetSelection()]])
IndexError: list index out of range
(tested recently on grass6.4.0 (rev 36255))
Am I doing somenthing wrong ?
Formerly with tcltk it would work (so when in this case, I start from
tcltk...)
Yours,
Vincent.
Le lundi 09 mars 2009 à 14:40 -0700, Michael Barton a écrit :
Choosing coordinates. Page after I pick UTM. The pulldown for zone is
misformatted and crammed at the top, and inaccessible.
2nd problem. Using EPSG code, after picking the code, there is a popup
that asks which projection to use. It is supposed to have the number,
followed by a description. Only the number is showing and not the
description. So there is no way to tell which number to pick.
3rd problem (not location wizard).
Also, the multifile import dialogs don't work on the Mac. Just
discovered that too.
This is because the wx.StaticBox is defined (in __dolayout) AFTER the
contents of the static box. wx.StaticBox MUST be defined BEFORE any of
its contents, or no controls work inside on the Mac. Because this is
currently in a separate method called after everything else in the
dialog, it has to be reconfigured. I might be able to work on it
tonight.
This probably is affecting the Location Wizard too, but I can't get
far enough to find out.
I didn't know that any recent changes had left these inoperable as I
have not had to create a location in awhile or had to import a dxf file.
Michael
On Mar 9, 2009, at 2:18 PM, Markus Neteler wrote:
> Michael
> On Mon, Mar 9, 2009 at 10:05 PM, Michael Barton <michael.barton@asu.edu
> > wrote:
>> Martin, et al.
>> Something has messed the location wizard. Formatting is problematic
>> so that
>> you can't get the pull downs for utm zone.
> In which subdialog is that precisely? Just for easier testing...
> Markus
>> I'm not sure what else is
>> happening, but wanted to get this out there ASAP because of the
>> immanent 6.4
>> release.
>> Michael
>> _______________________________________________
>> grass-dev mailing list
>> grass-dev@lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/grass-dev
