William,
I did an update and compile of GRASS 7 (trunk). v.krige still wouldn't compile, but the rest of it did. When I went to install it, I got the following error referencing modbuild. It seems to install, but I wonder if this means something to you. I also get an odd error when I start GRASS 7 that seems to suggest that it is not reading the folder "Application Support" correctly. I've copied that error below the make install error.
Michael
============ make install error ==============
cmb-MBP-2:grass70_dev cmbarton$ sudo make install
echo /Users/cmbarton/grass_dev/grass70_dev/bin.i386-apple-darwin10.2.0/grass70
make -C macosx install-macosx
echo /Users/cmbarton/grass_dev/grass70_dev/dist.i386-apple-darwin10.2.0/GRASS-7.0.app
mkdir -p -m 755 /Applications/GRASS/GRASS-7.0.app/Contents/MacOS
cd /Users/cmbarton/grass_dev/grass70_dev/dist.i386-apple-darwin10.2.0 ; tar cBf - GRASS-7.0.app | (cd /Applications/GRASS ; tar xBf - ) 2>/dev/null
cd /Users/cmbarton/grass_dev/grass70_dev/dist.i386-apple-darwin10.2.0 ; tar cBf - AUTHORS COPYING CHANGES REQUIREMENTS.html GPL.TXT | (cd /Applications/GRASS/GRASS-7.0.app/Contents/MacOS ; tar xBf - ) 2>/dev/null
cd /Users/cmbarton/grass_dev/grass70_dev/dist.i386-apple-darwin10.2.0 ; tar cBf - bin | (cd /Applications/GRASS/GRASS-7.0.app/Contents/MacOS ; tar xBf - ) 2>/dev/null
cd /Users/cmbarton/grass_dev/grass70_dev/dist.i386-apple-darwin10.2.0 ; tar cBf - docs | (cd /Applications/GRASS/GRASS-7.0.app/Contents/MacOS ; tar xBf - ) 2>/dev/null
cd /Users/cmbarton/grass_dev/grass70_dev/dist.i386-apple-darwin10.2.0 ; tar cBf - driver | (cd /Applications/GRASS/GRASS-7.0.app/Contents/MacOS ; tar xBf - ) 2>/dev/null
cd /Users/cmbarton/grass_dev/grass70_dev/dist.i386-apple-darwin10.2.0 ; tar cBf - etc | (cd /Applications/GRASS/GRASS-7.0.app/Contents/MacOS ; tar xBf - ) 2>/dev/null
cd /Users/cmbarton/grass_dev/grass70_dev/dist.i386-apple-darwin10.2.0 ; tar cBf - fonts | (cd /Applications/GRASS/GRASS-7.0.app/Contents/MacOS ; tar xBf - ) 2>/dev/null
cd /Users/cmbarton/grass_dev/grass70_dev/dist.i386-apple-darwin10.2.0 ; tar cBf - man | (cd /Applications/GRASS/GRASS-7.0.app/Contents/MacOS ; tar xBf - ) 2>/dev/null
cd /Users/cmbarton/grass_dev/grass70_dev/dist.i386-apple-darwin10.2.0 ; tar cBf - scripts | (cd /Applications/GRASS/GRASS-7.0.app/Contents/MacOS ; tar xBf - ) 2>/dev/null
if [ -eq 1 ] ; then cd /Users/cmbarton/grass_dev/grass70_dev/dist.i386-apple-darwin10.2.0 ; tar cBf - locale | (cd /Applications/GRASS/GRASS-7.0.app/Contents/MacOS ; tar xBf - ) 2>/dev/null ; fi
/bin/sh: line 0: [: -eq: unary operator expected
cd /Users/cmbarton/grass_dev/grass70_dev/dist.i386-apple-darwin10.2.0 ; tar cBf - include | (cd /Applications/GRASS/GRASS-7.0.app/Contents/MacOS ; tar xBf - ) 2>/dev/null
cd /Users/cmbarton/grass_dev/grass70_dev/dist.i386-apple-darwin10.2.0 ; tar cBf - lib | (cd /Applications/GRASS/GRASS-7.0.app/Contents/MacOS ; tar xBf - ) 2>/dev/null
chmod -R a+rX /Applications/GRASS/GRASS-7.0.app 2>/dev/null
touch /Applications/GRASS/GRASS-7.0.app
mkdir -p -m 755 "/Library/Application Support/GRASS/7.0"
mkdir -p -m 755 "/Library/Application Support/GRASS/7.0/Modules/bin"
mkdir -p -m 755 "/Library/Application Support/GRASS/7.0/Modules/docs/html"
mkdir -p -m 755 "/Library/Application Support/GRASS/7.0/Modules/etc"
mkdir -p -m 755 "/Library/Application Support/GRASS/7.0/Modules/lib"
/usr/bin/install -c /usr/local/lib/wxPython-unicode-2.8.10.1/lib/libwx_macud-2.8.0.dylib /Applications/GRASS/GRASS-7.0.app/Contents/MacOS/lib
/usr/bin/install -c /usr/local/lib/wxPython-unicode-2.8.10.1/lib/libwx_macud_gl-2.8.0.dylib /Applications/GRASS/GRASS-7.0.app/Contents/MacOS/lib
/usr/bin/install -c /usr/local/lib/wxPython-unicode-2.8.10.1/lib/libwx_macud_stc-2.8.0.dylib /Applications/GRASS/GRASS-7.0.app/Contents/MacOS/lib
/usr/bin/install -c /usr/local/lib/wxPython-unicode-2.8.10.1/lib/libwx_macud_gizmos-2.8.0.dylib /Applications/GRASS/GRASS-7.0.app/Contents/MacOS/lib
/usr/bin/install -c /usr/local/lib/wxPython-unicode-2.8.10.1/lib/libwx_macud_gizmos_xrc-2.8.0.dylib /Applications/GRASS/GRASS-7.0.app/Contents/MacOS/lib
cp -Rfp /usr/local/lib/wxPython-unicode-2.8.10.1/lib/python2.5/site-packages/wx-2.8-mac-unicode/wx /Applications/GRASS/GRASS-7.0.app/Contents/MacOS/etc/python
cp -Rfp /usr/local/lib/wxPython-unicode-2.8.10.1/lib/python2.5/site-packages/wx-2.8-mac-unicode/wxPython /Applications/GRASS/GRASS-7.0.app/Contents/MacOS/etc/python
cp -fp /usr/local/lib/wxPython-unicode-2.8.10.1/lib/python2.5/site-packages/wxversion.py /Applications/GRASS/GRASS-7.0.app/Contents/MacOS/etc/python
sed -i '' -e 's/^GRASS_WXBUNDLED=.*/GRASS_WXBUNDLED=1/' /Applications/GRASS/GRASS-7.0.app/Contents/MacOS/grass.sh
cd /Users/cmbarton/grass_dev/grass70_dev/dist.i386-apple-darwin10.2.0 ; tar cBf - modbuild | (cd /Library/Application Support/GRASS/7.0 ; tar xBf - ) 2>/dev/null
tar: modbuild: Cannot stat: No such file or directory
tar: Error exit delayed from previous errors.
/bin/ln -sfh "/Applications/GRASS/GRASS-7.0.app/Contents/MacOS/docs/html" /Library/Documentation/Help/GRASS-7.0
============ grass 7 startup error ==========
Last login: Fri Jan 1 11:57:23 on ttys000
'/Applications/Grass/GRASS-7.0.app/Contents/MacOS/grass.sh'; exit
cmb-MBP-2:~ cmbarton$ '/Applications/Grass/GRASS-7.0.app/Contents/MacOS/grass.sh'; exit
Rebuilding Addon HTML manual pages index...
Rebuilding Addon menu...
grep: /Library/Application: No such file or directory
grep: Support/GRASS/7.0/Modules/bin/r.prominence: No such file or directory
grep: /Users/cmbarton/Library/Application: No such file or directory
Python 2.6.1 found.
/Applications/Grass/GRASS-7.0.app/Contents/MacOS/etc/Init.sh: line 71: export: `.grass7': not a valid identifier
Cleaning up temporary files ...
Starting GRASS ...
Thanks
Michael
