[GRASS-dev] Mac OS X 10.10 , grass71-svn - fail to start
Hi Devs,
i updated my grass-svn installation, the build ends without errors but trying to start grass i got the following error :
epimac:~ epi$ grass71
Cleaning up temporary files...
  File "/usr/local/bin/grass71", line 1387, in <module>
    clean_temp()
  File "/usr/local/bin/grass71", line 1170, in clean_temp
    call([gfile("etc", "clean_temp")], stdout=nul, stderr=nul)
  File "/usr/local/bin/grass71", line 155, in call
    return subprocess.call(cmd, **kwargs)
  File "/usr/local/Cellar/python/2.7.9/Frameworks/Python.framework/Versions/2.7/lib/python2.7/subprocess.py", line 522, in call
    return Popen(*popenargs, **kwargs).wait()
  File "/usr/local/Cellar/python/2.7.9/Frameworks/Python.framework/Versions/2.7/lib/python2.7/subprocess.py", line 710, in __init__
    errread, errwrite)
  File "/usr/local/Cellar/python/2.7.9/Frameworks/Python.framework/Versions/2.7/lib/python2.7/subprocess.py", line 1335, in _execute_child
    raise child_exception
OSError: [Errno 2] No such file or directory
epimac:~ epi$
I don’t know what’s going on, it is possible that is my system that’s broken … and not grass
thanks for any help in debugging this issue.
Massimo.
On Thu, Feb 5, 2015 at 9:04 PM, epi <massimodisasha@gmail.com> wrote:
Hi Devs,
    clean_temp()
  File
line 522, in call
  File
    errread, errwrite)
  File
epimac:~ epi$
it calls binary clean_temp but it can't find it, do you have a file
etc/clean_temp? In the source code clean_temp.c is in lib/init.
Anna
Massimo.
grass-dev mailing list
grass-dev@lists.osgeo.org
Thanks Anna!
it was my fault. a typo in my bash_profile, my GISBASE was pointing to $GISBASE/lib.
Massimo.
Hi Devs,
Cleaning up temporary files…
File “/usr/local/bin/grass71”, line 1387, in
clean_temp()
File “/usr/local/bin/grass71”, line 1170, in clean_temp
call([gfile(“etc”, “clean_temp”)], stdout=nul, stderr=nul)
File “/usr/local/bin/grass71”, line 155, in call
File “/usr/local/Cellar/python/2.7.9/Frameworks/Python.framework/Versions/2.7/lib/python2.7/subprocess.py”, line 522, in call
File “/usr/local/Cellar/python/2.7.9/Frameworks/Python.framework/Versions/2.7/lib/python2.7/subprocess.py”, line 710, in init
errread, errwrite)
File “/usr/local/Cellar/python/2.7.9/Frameworks/Python.framework/Versions/2.7/lib/python2.7/subprocess.py”, line 1335, in _execute_child
epimac:~ epi$
it calls binary clean_temp but it can’t find it, do you have a file etc/clean_temp? In the source code clean_temp.c is in lib/init.
Anna
Massimo.
