I have observed similar behavior on macintel. Mainly, after an update.
If both X11 and terminal are opened grass.sh launches terminal and
nothing happens, quiting X11 sometimes fixes it and others I need to
quit terminal as well but I would swear that this happens also with
tcltk. I will keep an eye on it.
I thought you were going to work out some sort of Python way to
handle the need for an xterm? Or have you gotten that far yet?In all the tcl scripts I found that use it, it looks like they all
terminate the [command] with &.Question: is that on PPC or Intel or both? I've noticed a problem
with grass-xterm-wrapper on PPC - after running GRASS.app once,
future runs fail unless Terminal.app is quit first. It's strange
because it doesn't always happen, but I think it has something to do
with AppleScript. ie:double-click GRASS.app
Terminal starts
grass.sh runs in new Terminal window and Tcl GUI starts
GRASS.app quits
select mapsetdouble-click GRASS.app again
Terminal activates
grass.sh runs in new Terminal window and Tcl GUI starts (2 running now)
GRASS.app quits
click the Define location with projection values button, so it uses
grass-xterm-wrapper to run set_data in a new Terminal windowquit all running grass shells, but leave Terminal.app running.
Terminal activates
[grass.sh does NOT run]
GRASS.app quitsThere are also random cases where grass-xterm-wrapper starts a
Terminal window, but never runs the [command] - kinda similar to your
problem. Hmmm.It all works fine on my MacBook.
I asked the Applescript list earlier in the week but haven't heard
anything yet (it's an awfully quiet list...).I have a couple things I'm going to try. But I may have to revert
grass-xterm-wrapper if I can't figure out what's wrong.On Jun 23, 2007, at 7:53 PM, Michael Barton wrote:
> William,
> I just had a chance to test the Mac xterm wrapper--that uses the
> terminal rather than an xterm--in wxgrass. It hangs on exit, but it
> may be the way the command is issued.
> $GISBASE/etc/grass-xterm-wrapper -name xterm-grass -e $GISBASE/etc/
> grass-run.sh [command]
> Is this OK for the Mac wrapper?
> It works fine with TclTk.
William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
http://www.kyngchaos.com/All generalizations are dangerous, even this one.
grass-dev mailing list
grass-dev@grass.itc.it
Dr. Agust�n Diez Castillo
Departament de Prehistòria i Arqueologia
Universitat de València Phone: +34 963 86 42 42
Avda. Blasco Iba�ez, 28 Fax: +34 963 86 42 34
València 46010
