[GRASS-dev] Make/Configure Issue using Eclipse/Windows
I am trying to get GRASS compiled in a Eclipse/CDT environment on a Windows machine.
The approach includes wrapping the "configure / make /make install" -process in an ant file and works very well behaved on linux boxes.
On a windows box (using msys) "something" is going wrong regarding the header files. This is the first error produced by make, the follow-up errors are similar:
     [exec] gcc -I/d/Nutzer/ploewe/workspace/neo63/dist.i686-pc-mingw32/include -IC:\msys\1.0\local\include -g -O2 -IC:\msys\1.0\local\include -DPACKAGE=\""grasslibs"\" -D_FILE_OFFSET_BITS=64 -DPACKAGE=\""grasslibs"\" -I/d/Nutzer/ploewe/workspace/neo63/dist.i686-pc-mingw32/include -o OBJ.i686-pc-mingw32/auto_mask.o -c auto_mask.c
     [exec] In file included from auto_mask.c:17:
     [exec] G.h:2:23: rpc/types.h: No such file or directory
     [exec] G.h:3:21: rpc/xdr.h: No such file or directory
     [exec] G.h:42: error: syntax error before "XDR"
     [exec] G.h:42: warning: no semicolon at end of struct or union
     [exec] G.h:47: error: syntax error before '}' token
     [exec] make[3]: *** [OBJ.i686-pc-mingw32/auto_mask.o] Error 1
The GRASS sources have been downloaded from the SVN, so all files are available.
Suggestions, anyone ?
Peter
Dr. Peter Löwe
<peter.loewe@gmx.de>
249 Spiele für nur 1 Preis. Die GMX Spieleflatrate schon ab 9,90 Euro.
Neu: Asterix bei den Olympischen Spielen: http://flat.games.gmx.de
     [exec] gcc
Did you perform this step:
  http://www.webalice.it/marco.pasetti/grass/BuildFromSource.html#Xdr
I.e. does C:\msys\1.0\local\include\rpc\ exist?
Hi Glynn,
-------- Original-Nachricht --------
Datum: Wed, 14 May 2008 19:12:08 +0100
Von: Glynn Clements <glynn@gclements.plus.com>
An: peter.loewe@gmx.de
CC: grass-dev@lists.osgeo.org
Betreff: Re: [GRASS-dev] Make/Configure Issue using Eclipse/Windows
Windows machine.
are similar:
> [exec] gcc
available.
Yes it does.
Still puzzled,
Peter
GMX startet ShortView.de. Hier findest Du Leute mit Deinen Interessen!
Jetzt dabei sein: http://www.shortview.de/?mc=sv_ext_mf@gmx
> Windows machine.
> are similar:
> > [exec] gcc
> available.
Yes it does.
How are the MSys paths getting there, and how are they used?
If the command line is being parsed by a Unix-style shell, the
backslash characters will be "eaten", and probably need to be forward
slashes instead, i.e. "C:/msys/...". You may even need to use e.g.
"/c/msys/..." instead of "C:". If MSys' bash shell is being used, the
path should just be "/usr/local/include".
OTOH, if MSys' bash shell *isn't* being used, then /d/Nutzer/...
probably won't work; Windows itself isn't going to understand that
path.
> Windows machine.
> are similar:
> > [exec] gcc
> available.
Yes it does.
path.
