I wrote an addon (r.denoise) that I would like to be able to use with g.extension. I am running 6.5.svn from my home directory, so that I have permissions to install extra modules without sudo. The installation fails, telling me that the module did not install correctly (see below). I have a few questions:
- is this a problem with 1) my 6.5.svn installation, 2) with g.extension, or 3) with the r.denoise addon?
- if 1) or 3), how can I fix it? Do I need to change the Make file for r.denoise?
I have trouble installing other addons (r.surf.volcano, r.colors.quantiles), so if the problem is with the addons, then it will affect them, too.
John
GRASS 6.5.svn (thingy):~/laptop/grassdata/thingy > g.extension r.denoise
Fetching <r.denoise> from GRASS-Addons SVN (be patient)...
A r.denoise/description.html
A r.denoise/r.denoise
A r.denoise/Makefile
Checked out revision 39770.
Compiling r.denoise...
/home/mbessjs3/usr/local/grass-6.5.svn/include/Make/Script.make:47: warning: overriding commands for target `install'
/home/mbessjs3/usr/local/grass-6.5.svn/include/Make/Rules.make:82: warning: ignoring old commands for target `install'
if [ ! -d /home/mbessjs3/usr/local/src/grass/develbranch_6/dist.i686-pc-linux-gnu/scripts ]; then mkdir -p /home/mbessjs3/usr/local/src/grass/develbranch_6/dist.i686-pc-linux-gnu/scripts; fi
/usr/bin/install -c r.denoise /home/mbessjs3/usr/local/src/grass/develbranch_6/dist.i686-pc-linux-gnu/scripts/r.denoise
make htmlscript scriptstrings
make[1]: Entering directory `/media/OS/Users/mbessjs3/Documents/grassdata/thingy/PERMANENT/.tmp/mbessjs3-pc/16278.0/r.denoise'
make /home/mbessjs3/usr/local/src/grass/develbranch_6/dist.i686-pc-linux-gnu/docs/html/r.denoise.html HTMLSRC=/home/mbessjs3/usr/local/src/grass/develbranch_6/dist.i686-pc-linux-gnu/scripts/r.denoise
make[2]: Entering directory `/media/OS/Users/mbessjs3/Documents/grassdata/thingy/PERMANENT/.tmp/mbessjs3-pc/16278.0/r.denoise'
if [ "/home/mbessjs3/usr/local/src/grass/develbranch_6/dist.i686-pc-linux-gnu/scripts/r.denoise" != "" ] ; then GISRC=/home/mbessjs3/usr/local/src/grass/develbranch_6/dist.i686-pc-linux-gnu/demolocation/.grassrc65 GISBASE=/home/mbessjs3/usr/local/src/grass/develbranch_6/dist.i686-pc-linux-gnu PATH="/home/mbessjs3/usr/local/src/grass/develbranch_6/dist.i686-pc-linux-gnu/bin:$PATH" LD_LIBRARY_PATH="/home/mbessjs3/usr/local/src/grass/develbranch_6/dist.i686-pc-linux-gnu/bin:/home/mbessjs3/usr/local/src/grass/develbranch_6/dist.i686-pc-linux-gnu/lib:/home/mbessjs3/usr/local/grass-6.5.svn/lib" LC_ALL=C /home/mbessjs3/usr/local/src/grass/develbranch_6/dist.i686-pc-linux-gnu/scripts/r.denoise --html-description < /dev/null | grep -v '</body>\|</html>' > r.denoise.tmp.html ; true ; fi
/home/mbessjs3/usr/local/grass-6.5.svn/tools/mkhtml.sh r.denoise ; mkdir -p /home/mbessjs3/usr/local/src/grass/develbranch_6/dist.i686-pc-linux-gnu/docs/html ; /usr/bin/install -c -m 644 r.denoise.tmp.html /home/mbessjs3/usr/local/src/grass/develbranch_6/dist.i686-pc-linux-gnu/docs/html/r.denoise.html ; for file in *.png *.jpg ; do head -n 1 $file | grep '^#!' > /dev/null ; if [ $? -ne 0 ] ; then /usr/bin/install -c -m 644 $file /home/mbessjs3/usr/local/src/grass/develbranch_6/dist.i686-pc-linux-gnu/docs/html ; fi done 2> /dev/null ; true
make[2]: Leaving directory `/media/OS/Users/mbessjs3/Documents/grassdata/thingy/PERMANENT/.tmp/mbessjs3-pc/16278.0/r.denoise'
GISRC=/home/mbessjs3/usr/local/src/grass/develbranch_6/dist.i686-pc-linux-gnu/demolocation/.grassrc65 GISBASE=/home/mbessjs3/usr/local/src/grass/develbranch_6/dist.i686-pc-linux-gnu PATH=/home/mbessjs3/usr/local/src/grass/develbranch_6/dist.i686-pc-linux-gnu/bin:$PATH LD_LIBRARY_PATH="/home/mbessjs3/usr/local/src/grass/develbranch_6/dist.i686-pc-linux-gnu/lib:/home/mbessjs3/usr/local/grass-6.5.svn/lib" g.parser -t r.denoise | sed s/\"/\\\\\"/g | sed 's/.*/_("&")/' > /home/mbessjs3/usr/local/grass-6.5.svn/locale/scriptstrings/r.denoise_to_translate.c ; true
/bin/sh: cannot create /home/mbessjs3/usr/local/grass-6.5.svn/locale/scriptstrings/r.denoise_to_translate.c: Directory nonexistent
make[1]: Leaving directory `/media/OS/Users/mbessjs3/Documents/grassdata/thingy/PERMANENT/.tmp/mbessjs3-pc/16278.0/r.denoise'
make mancmd
make /home/mbessjs3/usr/local/src/grass/develbranch_6/dist.i686-pc-linux-gnu/man/man1/r.denoise.1 MANSRC=/home/mbessjs3/usr/local/src/grass/develbranch_6/dist.i686-pc-linux-gnu/docs/html/r.denoise.html
mkdir -p /home/mbessjs3/usr/local/src/grass/develbranch_6/dist.i686-pc-linux-gnu/man/man1
GRASS_PERL=/usr/bin/perl VERSION_NUMBER=6.5.svn sh /home/mbessjs3/usr/local/src/grass/develbranch_6/tools/g.html2man/g.html2man /home/mbessjs3/usr/local/src/grass/develbranch_6/dist.i686-pc-linux-gnu/docs/html/r.denoise.html /home/mbessjs3/usr/local/src/grass/develbranch_6/dist.i686-pc-linux-gnu/man/man1/r.denoise.1 1
Converting: /home/mbessjs3/usr/local/src/grass/develbranch_6/dist.i686-pc-linux-gnu/docs/html/r.denoise.html to /home/mbessjs3/usr/local/src/grass/develbranch_6/dist.i686-pc-linux-gnu/man/man1/r.denoise.1
Installing r.denoise...
ERROR: Module did not install properly
Dr John Stevenson
Postdoctoral Research Associate
School of Earth, Atmospheric and Environmental Sciences
Williamson Building (Room 2.42)
University of Manchester
Manchester M13 9PL, UK
tel. +44(0)161 306 6585; fax. +44(0)161 306 9361;
john.stevenson@manchester.ac.uk
