(copied here from grass-user)
Related to below problem, would it be possible to add a
make install
target to all Makefiles? Then especially the GRASS Addons
installation would be greately simplified.
On Sun, Mar 30, 2008 at 12:57 PM, Gazz1982 <garynobles@yahoo.com> wrote:
That doesn't seem to work,
Here is my directory structure under grass
bin
bwidget
docs
driver
etc
fonts
include
lib
scriptsI copied the r.horizon2 folder into the bin directory and tried to make it
it returned the same errorI have superuser/root permissions
I'm sure when i do it once I will be able to do it again and again!
Thanks for your help
there isn't an imagery or raster folder should I make one in the grass
directory?Nikos Alexandris wrote:
> On Sat, 2008-03-29 at 16:20 -0700, Gazz1982 wrote:
>> I have just been converted to Linux after struggling with cgywin!
>> How do I install a new grass module, in this case I have the file
>> r.horizon2.tar.gz on my desktop and my $GISBASE is /usr/lib/grass
> (You might need to be superuser/root to do "make install" in the end)
> In general it must be something like:
> 1. copy "add-on" directory to /where/your/grass/source/is under the
> respective generic module category
> e.g. for i.pr it would be:
> cp -r i.pr /where/your/grass/source/is/imagery/
> 2. configure grass
> cd /where/your/source/is/
> ./configure #with your parameters
> 3. go to the "add-on" directory and "make it"
> e.g.
> cd /imagery/i.pr
> make
> 4. back to grass source directory
> make install
>> I've done this before but I can't remember the commands and where
>> everything
>> should go
>> Thanks
> Hope this helps (as it helped me once when somebody told me how make it)
> Cheers,
> Nikos
