[GRASS-dev] make MODULE_TOPDIR= not enforced on grass-addons building with trunk
cd $root/grass-addons/grass7/imagery
make MODULE_TOPDIR=$root/grass_trunk/
Makefile:19: ../include/Make/Dir.make: No such file or directory
make: *** No rule to make target `../include/Make/Dir.make'. Stop.
MODULE_TOPDIR = ..
# i.fusion.brovey deprecated
SUBDIRS = \
        i.eb.h_sebal95 \
        i.edge \
        i.evapo.potrad \
        i.evapo.senay \
        i.evapo.zk \
        i.gravity \
        i.histo.match \
        i.lmf \
        i.points.auto \
        i.rotate \
        i.segment \
        i.vi.mpi
include $(MODULE_TOPDIR)/include/Make/Dir.make
default: subdirs
Yann Chemin
Researcher@IWMI
Skype/FB: yann.chemin
To me this error suggests that $root is undefined at your end.
Probably you wanted to write $HOME?
[neteler@oboe imagery]$ make MODULE_TOPDIR=$HOME/grass70
works just fine (the precompiled GRASS 7.svn is in my $HOME/grass70)
Hi Markus,
the problem seems to come from /grass-addons/grass7/imagery/Makefile
#make grass-addons/grass7/imagery
cd $HOME/grass_dev/grass-addons/grass7/imagery
make MODULE_TOPDIR=$HOME/grass_dev/grass70
Trying from
I get the same result
Yann Chemin
Researcher@IWMI
I compared it to the corresponding raster/Makefile, no differences
which would be relevant here.
Strange, no such problem here. Please check your make version, too.
I use
make -v
GNU Make 3.82
I use
make -v
GNU Make 3.82
Hi Markus,
make -v
GNU Make 3.81
will see to upgrade the version...
Ciao,
Yann
Yann Chemin
Researcher@IWMI
