Hallo,
following patch makes GRASS modules able to use --verbose flag or set
GRASS_VERBOSE environment variable.
In the code:
if (module->verbose)
printf("Blah, blah, blah, blah\n");
or
G_percent(row, nrows, 2);
I thing, that according to Eric Steven Raymond, if the program does
not have anything interesting to say, it should say nothing. This is
good for embeding GRASS in some web server application or for some scripts.
But how to use it in old GRASS modules, so that the number of modules,
which must be corrected by hand, is as low as possible? Do you thing,
this is useful? Shall I put apply this to cvs?
Example session:
GRASS 6.3.cvs (spearfish60):~ > export GRASS_VERBOSE=0
GRASS 6.3.cvs (spearfish60):~ > r.example --help
Description:
My first raster module
Keywords:
keyword1, keyword2, keyword3
Usage:
r.example [-q] input=name output=name [--overwrite] [--verbose]
Flags:
-q Quiet
--o Force overwrite of output files
--v Verbose module output
Parameters:
input Name of input raster map
output Name for output raster map
GRASS 6.3.cvs (spearfish60):~ > r.example in=aspect out=aspect
GRASS 6.3.cvs (spearfish60):~ > r.example in=aspect out=aspect --v
93%
GRASS 6.3.cvs (spearfish60):~ > GRASS 6.3.cvs (spearfish60):~ > export GRASS_VERBOSE=1
GRASS 6.3.cvs (spearfish60):~ > r.example in=aspect out=aspect Blah, blah, blah, blah
93%
Looking forward to your comments
Jachym
Index: include/gis.h
RCS file: /home/grass/grassrepository/grass6/include/gis.h,v
retrieving revision 1.33
diff -u -r1.33 gis.h
--- include/gis.h 19 Aug 2006 12:52:21 -0000 1.33
+++ include/gis.h 19 Sep 2006 14:43:42 -0000
@@ -570,6 +570,7 @@
char *keywords; /* Keywords describing module */
/* further items are possible: author(s), version */
int overwrite; /* overwrite old files */
+ int verbose; /* print all informations about progres and so on */
struct TimeStamp
Index: lib/gis/parser.c
RCS file: /home/grass/grassrepository/grass6/lib/gis/parser.c,v
retrieving revision 1.85
diff -u -r1.85 parser.c
--- lib/gis/parser.c 17 Sep 2006 21:50:00 -0000 1.85
+++ lib/gis/parser.c 19 Sep 2006 14:43:43 -0000
@@ -136,6 +136,7 @@
static int n_opts = 0 ;
static int n_flags = 0 ;
static int overwrite = 0 ;
+static int verbose = 0 ;
static struct Flag first_flag; /* First flag in a linked list */
static struct Flag *current_flag; /* Pointer for traversing list */
@@ -171,6 +172,7 @@
static int split_opts();
static int check_multiple_opts();
static int check_overwrite();
+static int check_verbose();
static int interactive( char *);
static int interactive_flag( struct Flag *);
static int interactive_option( struct Option *);
@@ -728,6 +730,12 @@
overwrite = 1;
+ /* Verbose option */
+ else if ( strcmp(ptr,"--v") == 0 || strcmp(ptr,"--verbose") == 0 )
+ module_info.verbose = 1;
/* Force gui to come up */
else if ( strcmp(ptr,"--ui") == 0 )
@@ -794,6 +802,9 @@
if ( check_overwrite () )
return -1;
+ if (check_verbose ())
return(0) ;
@@ -932,6 +943,10 @@
len=show(item,len);
+ strcpy (item, " [--verbose]");
+ len=show(item,len);
fprintf (stderr, "\n");
/* Print help info for flags */
@@ -960,8 +975,9 @@
if (new_prompt)
- fprintf(stderr," --o %s\n", _("Force overwrite of output files")) ;
+ fprintf(stderr," --o %s\n", _("Force overwrite of output files")) ;
+ fprintf(stderr," --v %s\n", _("Verbose module output")) ;
/* Print help info for options */
@@ -1334,9 +1350,10 @@
if (new_prompt)
fprintf(stdout, " [--<b>overwrite</b>] ");
+ fprintf(stdout, " [--<b>verbose</b>] ");
fprintf(stdout, "\n");
fprintf(stdout, "<DT><b>--overwrite</b></DT>\n");
fprintf(stdout, "<DD>Force overwrite of output files</DD>");
+ fprintf(stdout, "<DT><b>--verbose</b></DT>\n");
+ fprintf(stdout, "<DD>Verbose module output</DD>");
fprintf(stdout, "</DL>\n");
@@ -2144,6 +2165,34 @@
return(error) ;
+/* Check verbose */
+static int check_verbose (void)
+ char *verstr;
+ int verb;
+ verb = 0;
+ /* Check the GRASS VERBOSE variable */
+ if ( (verstr = G__getenv ( "VERBOSE" )) ) {
+ verb = atoi ( verstr );
+ /* Check the GRASS_OVERWRITE environment variable */
+ if ( (verstr = getenv ( "GRASS_VERBOSE" )) ) {
+ if (atoi ( verstr ))
+ verb = 1;
+ if ( verb ) {
+ /* Set the environment so that programs run in a script also obey --o */
+ putenv("GRASS_OVERWRITE=1");
+ /* No need to check options for existing files if overwrite is true */
+ return(verb) ;
static int interactive( char *command)
grass-dev mailing list
grass-dev@grass.itc.it
